Old 08-25-2009
HermitScott's Avatar
HermitScott is on a distinguished road
Will a yanmar 2QM20 fit in a Catalina30?
I just drove a 7 hour round trip to pick up this motor. Got it for a song, well actually a kayak and $350. I hear this will get her up to hull speed. I am going to rebuild this engine whether it needs it or not, cause that's just how I roll. I was wondering if anyone has or has had a C30 with this engine in it? If you have nay pics of what it looks like after you use a shoe horn to get it in the compartment(if it's possible) I would appriciate it.
I posted a question not too long ago about trying to put a Perkins 4-108 in my C30,lol. Yeah right.
Any way I own this one now and I hope someone can verify that it will fit with out taking up half the salon.
Also any expectations on performance would be cool. What prop are you using?
C30 Event Horizon
Old 08-25-2009
hertfordnc is on a distinguished road
I can't speak to the Catalina but my Nicholson 31 displaces 7 tons and this little engine had no trouble keeping her at near hull speed for 24 hours straight in a pretty brisk head wind.
I recently rebuilt the transmission myself in the boat. It was remarkably simple to work on.
I keep a google alert on 2Qm20 and 3QM20 (that's I how I found your post)
A while back I got an alert abot a starter on ebay- picked up a spare for $100(they sell for $1000)
Do you have books?
Dave
In over my head?
First Boat, a well-equipped 1977 Camper Nicholson 31
What is all this stuff and how does it work?
Old 08-25-2009
I have a maual to the 2QM15. I don't know how that ended up with this engine.
C30 Event Horizon
Old 08-25-2009
NCC320 is on a distinguished road
Hermit,
Just curious...didn't you already rebuild an engine for your boat? Why the change to the Yanmar (good engines though)?
Old 08-25-2009
The engine I have now is a yanamr ysm12. 12hp, 1 hour rating, 10 hp continuous. It's a little weak for the C30.
The 2QM20 is 20 hp continuous 22 1 hour rating. It should be a big difference if it will fit in there.
C30 Event Horizon
Old 08-25-2009
sailor50 is on a distinguished road
Are you wishing to turn this Catalina into a MacGregor?
Old 08-25-2009
The universals that are routinely installed in C30's are 20 some HP. I just don't know how they compare in size. I can't find specs anywhere.
C30 Event Horizon
Old 08-27-2009
anyone?
C30 Event Horizon
Old 09-20-2009
azcanyon is on a distinguished road
Yanmar ysm12
Did you sell your Yanmar YSM12 you replaced?
Thanks,
ken
Old 09-20-2009
Maine Sail's Avatar
Hermit
I re-powered a C-30 with a Universal M3-20B from a Yanmar 1GM. They will also fit an M-25. If I remember correctly the Yanmar 2GM was a tad to tall for the C-30 as that is what I originally wanted. Remember it has to fit under the settee and the galley counter and you need the room for your exhaust elbow.
Simply measure the height to the settee from the engine bed then measure your min height from the motor mounts on the Yanmar to the top of the valve cover. I think you might be all set length wise but even that is very tight as the shaft log is "right there". As it was my water pump was so tight against the front of the settee that I ahd to cut an access port for impeller changes with an M3-20B..
The old one lunger pushed my C-30 along just fine even up some heavy current rivers. Have you checked to make sure you are not over or under propped??? I would absolutely make sure your prop is right before diving into an engine replacement..
______
-Maine Sail / CS-36T
Yanmar 2QM20 Exhaust part - help hertfordnc Gear & Maintenance 19 12-13-2010 06:07 PM
Beneteau vs. Yanmar – Green vs. Red Cooling Fluid Swesail Gear & Maintenance 37 04-14-2009 12:32 PM
Yanmar 2QM20 tranmission- substitutions? hertfordnc Gear & Maintenance 1 01-19-2009 05:29 AM
Yanmar Problem Solved... Warren M. Gear & Maintenance 1 09-01-2008 09:39 PM
Yanmar 3gmd Question nk235 Gear & Maintenance 4 03-12-2008 04:48 PM
