Old 08-25-2009
voice3 is on a distinguished road
Spot painting a mast with Awlgrip
I have a non-ionized aluminum mast, which has some areas where the paint has worn off and also has spots of galvanic corrosion. However, on the majority of the mast the paint is in OK condition. I know Awlgrip paint (its currently painted with Awlgrip) requires extensive priming in order to stick effectively, but is it possible to just prime and paint some areas of the mast without repainting the whole thing? I would like to hear some views on this.
Thanks,
Matt
Old 08-25-2009
While an awlgrip finish is said to be difficult to repair, I believe that that means it's tough to retouch/repair in a way that is not apparent once it's been done.
We touched up some dock rash and the odd transom nick after an awlgrip job, you could see it alright, but it looked better than the original scar. I just used the paint, activator and a foam brush.. no reducer.
I think you could sand out the damaged area, do a vinegar wash on your "non-anodized" (ionized??) and repaint the area after re-priming... it won't look like it never happened, but probably better than what you're looking at now...
The tough part will probably getting the small amount of paint you'll need.
1984 Fast/Nicholson 345
Old 08-25-2009
Yes, sorry, non-anodized.
I'm not worried that much about the paint matching. I just want to stop the current corrosion and prevent new corrosion from taking hold. How did the paint hold up with your repair?
Old 08-25-2009
speciald's Avatar
Special Delivery
speciald is on a distinguished road
Send a message via Skype™ to speciald
For little scratches and nicks, Awlgrip sells "nail polish" containers of matching paint like you ould buy to fix scratches on your car.
Old 08-25-2009
Unfortunately the areas I need to paint are a bit too big for something like that.
Old 08-25-2009
Gary M's Avatar
Gary M is on a distinguished road
The Awlgrip site details just about every option including touching up smaller sections. It should be no problem but check there for details. Some 545 primer and top coat and you should be fine.
Good Luck
Gary
Old 08-26-2009
Good Luck
Gary
Thanks, I'll check it out.
Old 08-26-2009
awriter111's Avatar
Dalitecomanmewangohome
awriter111 is on a distinguished road
Send a message via AIM to awriter111
ok'y dokety
Caribbean Traveller
Old 08-26-2009
awriter111's Avatar
hello
Caribbean Traveller
Old 08-26-2009
awriter111's Avatar
hello there
Caribbean Traveller
Adjusting Your Rig Giulietta Gear & Maintenance 87 09-02-2011 10:32 PM
Spot Painting Bottom Paint dave6330 Gear & Maintenance 4 07-20-2007 04:05 PM
Yawl Info Needed sailortonyb1 Boat Review and Purchase Forum 5 01-18-2006 04:51 AM
