110 Volt Windlass? - SailNet Community
post #1 of 6 Old 08-26-2009 Thread Starter
110 Volt Windlass?
We have a Cascade 36 sailboat with no windlass. I'm doing the preliminary research so we can come up with a plan to add one. I've searched through old messages in this forum and have seen many discussions of how to get enough power to a windlass. It seems that everybody either spends a fortune on heavy wire or adds a heavy battery in the bow. I don't like either choice.
We have a 2500 Watt inverter, so I thought it might make sense to use a 110V winch. I would only need 14AWG or 12AWG wire. A GFCI would protect against danger from an electrical failure. I would want a vertical windlass to keep the motor below deck.
I haven't been able to locate 110V windlass small enough for our boat, so I thought I'd ask whether anybody here has thoughts on where to get one, or why they're so hard to find.
The one thing you should never leave the dock without: your humility.
SailorByFate is offline
post #2 of 6 Old 08-26-2009
n0w0rries's Avatar
If everybody spends a fortune on heavy wire or a cable, that's probably because there isn't a better solution.
If you really have your heart set on it, it might be a custom job. If you could find a windlass with a vertical 12v motor that's shot at a salvage shop, you could replace the motor with a 110v motor. Gearing may be an issue though. Since you will lose some energy converting from 12v to 110v I would think that would be a pretty hard hit on the battery bank.
Good luck.
n0w0rries is offline
post #3 of 6 Old 08-26-2009 Thread Starter
I'll be running my engine and 80 Amp alternator when using the windlass, so battery usage is not really a problem. The inverter runs at about 90% efficiency at high loads like this, so that won't be a significant factor either.
I'd really like to get something off-the-shelf. Replacing the 12 volt motor with a 110V motor sounds to difficult and risky for me to take on.
Thanks for your ideas!
post #4 of 6 Old 08-26-2009
Send a message via AIM to negrini Send a message via Yahoo to negrini Send a message via Skype™ to negrini
Also, it will be very difficult to mach the recommended speed/torque on a 110 AC 60Hz motor. Do yourself a favor, stay at safe 12V, specially on a salty prone area like the bow (you'll find way difficult to seal water intrusion along the years), and use a 12V DC motor, that provides a safe speed and strong torque as well. On a 36 feet, cabling is not that long nor bulky .....
Nave Rara
Beneteau Oceanis 43
negrini is offline
post #5 of 6 Old 08-26-2009
davidpm's Avatar
They make a 24 volt windless. May cut down on wiring but still be safe and standard.
davidpm is offline
post #6 of 6 Old 08-26-2009
mitiempo's Avatar
24 volt will save on wire size, but then he'll need a 24 volt battery bank.
Brian
mitiempo is offline
Installing an anchor windlass GoodOldBoat Good Old Boat 9 05-23-2015 05:53 PM
Installing an anchor windlass GoodOldBoat Good Old Boat 2 06-05-2013 10:10 PM
Choosing and Installing an Electric Windlass Sue & Larry Gear and Maintenance Articles 0 09-06-2002 08:00 PM
The Great Windlass Debate SailNet Seamanship Articles 0 11-30-2001 07:00 PM
The Great Windlass Debate SailNet Gear and Maintenance Articles 0 11-30-2001 07:00 PM
