Old 08-26-2009
cghubbell's Avatar
1977 CS27 ~ Ravat
cghubbell is on a distinguished road
Name that fitting...
Can anyone tell me what this fitting is for? Specifically, the circled hooks to the left of where my furler attaches. It's on the bow of my 1977 CS27, and so far I haven't found anyting to use it for. Yes, I'm new to this - it's my first boat so don't beat me too hard if its obvious!
I'm guessing something to do with anchoring? I've only sailed it from the dock, so that might explain why I haven't used it yet.
Thanks,
Chris
sailing
Old 08-26-2009
14432's Avatar
14432 is on a distinguished road
Hooks like that are typically mounted at the gooseneck to accept a luff cringle/grommet when reefing the main (i.e. a new tack)
Old 08-26-2009
saildork's Avatar
saildork is on a distinguished road
Looks like a reefing hook to me. Could have been used for reefing a hank-on jib/genoa. Just a guess.
Sailing isn't a matter of life and death. It's much more important than that!
Old 08-26-2009
cghubbell's Avatar
1977 CS27 ~ Ravat
Does that mean it's not a normal thing to find on the bow? It's a looooong way from the gooseneck if someone installed it in the wrong place
CS27 #1254 ~ Ravat
Port of Rochester
Lake Ontario
Old 08-26-2009
Sabreman's Avatar
Sabreman will become famous soon enough
Agreed. Could also be for an asymmetrical spinnaker tack line, although I'd move the headstay to the aft hole and use a block instead of the fitting shown.
Sabre 38 "Victoria"
Old 08-26-2009
cghubbell's Avatar
1977 CS27 ~ Ravat
Aha, could it be part of the rigging for my gennaker? I haven't yet learned how to do that - I have the pole, blocks, lines, and sail, but haven't had a chance to figure out how to rig it yet.
CS27 #1254 ~ Ravat
Port of Rochester
Lake Ontario
Old 08-26-2009
jjablonowski's Avatar
jjablonowski is on a distinguished road
Attachment point for a furling-headsail prefeeder?
Just a guess, from where it sits.
Old 08-26-2009
midnightsailor's Avatar
midnightsailor is on a distinguished road
Those are headsail fast tack hooks used for attaching the tack of the headsail. They are usually found on boats which are raced to speed up head sail changes and for conveinience. Otherwise boats usually use a type of snap shackle or "fast" pin to attach the tack of the sail to the headstay chainplate. You may need this for your gennacker as you guessed. Rick
Old 08-26-2009
mitiempo's Avatar
I agree with midnightsailor. It was standard equipment on the CS27, and although you have a furler, not all CS27s do (including mine)
Brian
CS27
Old 08-26-2009
mikehoyt's Avatar
mikehoyt is on a distinguished road
Midnight is right. I have furling gear and hooks. I use the hooks when using my non furling headsails.
Similar hooks at gooseneck of boom are usually for reefing.
Mike
Sta-Lok or ? killarney_sailor Gear & Maintenance 22 11-06-2008 08:55 PM
need help locating a boom vang fitting ChrisandTammy Gear & Maintenance 9 06-27-2008 05:43 PM
Mounting Deck Hardware Tom Wood Gear and Maintenance Articles 0 06-25-2002 08:00 PM
Ten Lessons of Fitting Out Micca Hutchins Gear and Maintenance Articles 0 03-14-2001 07:00 PM
Ten Lessons of Fitting Out Micca Hutchins Her Sailnet Articles 0 03-14-2001 07:00 PM
