Old 08-29-2009
traumadoc is on a distinguished road
How to remove fiberglass resin from non-skid deck
I took my Precision 165 into a local boatworks to have some work done. They spilled what appears to be fiberglass resin on the non-skid deck and the steps into the cabin. They apologized, but said there is nothing they can do other than paint over it.
Does anyone know of a solvent that would remove this from the non-skid, but not damage the gelcoat?
I appreciate any ideas!
Old 08-29-2009
DrB DrB is offline
DrB is on a distinguished road
You're stuck...
Epoxy is pretty inert to nearly all solvents. Acetone will soften it slightly, but it will also do the same to the gel coat.
You can try and scrap it off with a razor blade or a grind it down with a dremel.
DrB
If you liked my advice/response, give me some rep points. If you didn't......well what do you expect, it was free.
Old 08-29-2009
scottyt is on a distinguished road
if every thing was waxed before, a little hammer ( edit when i say a little hammer i ment a little hammer ) tapping it might pop it loose. this only works if its drips or globs.
you could also try small pieces of dry ice applied only to the epoxy. dont tap it when cold, but let it warm up then try the tap
Old 08-29-2009
Capnblu is on a distinguished road
I would be inclined to let the UV do a number on it for several months, then go at the edge with a razor sharp knife, at a real low angle. It will probably peel off. I would wait till it turned really yellow. As long as the area where it spilled wasn't too rough, it should all come off if you go slow. Post a pic if you can, and we might see another solution for you.
Why, why, why?
is the Carribean coastal sailing or offshore? troyaux Boat Review and Purchase Forum 40 02-23-2010 11:51 PM
How does an old boat fail ? LookingForCruiser Sailboat Design and Construction 7 01-17-2008 04:59 PM
High Tech vs traditional-Comments? Pangaea General Discussion (sailing related) 38 08-07-2007 01:07 AM
