-   -   Cal 29 keel bolts ? (http://www.sailnet.com/forums/gear-maintenance/57569-cal-29-keel-bolts.html)
tommays 08-29-2009 08:16 PM
Cal 29 keel bolts ?
:confused:
http://www.richardanderson.net/TechS...20Brochure.pdf
In looking at a 1970 CAL 29 I did not see keels bolts ,just a lifting hoop that looked like it was used to set the lead into the hull mold
In reading the Brochure it says Lead 3350# inside integral fiberglass keel which seems good
If anybody can confirm this thank you :D
Yes i know about the rusting steel mast beam ;)
painkiller 08-29-2009 08:30 PM
Originally Posted by tommays (Post 518191)
:confused:
Yeah, all the Cals had encased keels, so no keel bolts. I had a 1978 3-29.
SEO by vBSEO 3.6.1
