Old 08-30-2009
ArgleBargle is on a distinguished road
boat drano
Hi
PROBLEM: shower sump pump drains increasingly slowly.
ASSESSMENT: pump itself and accessible area immediately under shower drain seem clear.
I suspect a "hair ball" etc somewhere in the hoses between the shower drain and shower sump pump.
worried about standard household products effects on hoses. We have tried vinegar without much effect.
QUESTION: apart from ripping everything out, anyone have any experience with safe chemical means of cleaning this out?
many thanks in advance
Old 08-30-2009
speciald's Avatar
Special Delivery
speciald is on a distinguished road
Send a message via Skype™ to speciald
Is there a filter between the drain and pump? If not there should be. Did you take the pump apart? The outlow and impeller may be clogged.. I've used Drano without problems on sink rains. Pump housing and impeller should be immune to Drano.
Old 08-30-2009
LarryandSusanMacDonald's Avatar
SaltwaterSuzi/CapnLarry
LarryandSusanMacDonald will become famous soon enough
Many shower drains I have seen have a small filter before the pump. Does yours have one? It could be clogged. Check it and take it apart and remove the hairball. Careful - it really stinks.
If it's not the filter, it could be the pump itself. You have to take it apart and repair or clean it. Chemistry is not the answer.
Saltwater Suzi and Cap'n Larry
"A sailboat is a fickle mistress. You’ve got to buy her things. You’ve got to understand everything about her. What you don’t know she’ll use against you." -Captain Larry
Naming and Renaming Your Boat Sue & Larry Cruising Articles 0 12-15-2003 07:00 PM
Fine-Tuning the Autopilot, Part Two Dan Neri Gear and Maintenance Articles 0 10-13-2003 08:00 PM
Performing in Light Air Brian Hancock Learning to Sail Articles 0 01-15-2003 07:00 PM
The Balance of Hull and Sails Steve Colgate Learning to Sail Articles 0 05-25-2000 08:00 PM
