Old 09-01-2009
CapnRon47 is on a distinguished road
Single handling Safety and Convenience Mods
In a recent thread I announced my first solo sail. Well, I am already thinking about ways to make single handling the boat easier and safer. And I would like some input on these ideas.
Let me start with the convenience aspect first. I have a swing keel boat for which I need to lower the keel for good sailing performance but raise the keel every time I return to dock. The Keel is 4,000 lbs of lead and while it has a multiple purchase system, it eventually leads up to a winch on the cabin roof that I have to operate by hand.
The keel line comes up thru a port in the roof, by the mast, (just to the left of the double pulleys)
passes aft thru a stopper (clutch) and then to the a Harken 44, two speed winch.
With the Dodger up the winch handle cannot go all the way around, but I do have a ratcheting handle so it alternates between the two speeds. But with the multiple purchase system (down below) I end up having to winch in a lot of line ( maybe 20' or more), and it takes quite a bit of effort, especially with no crew to take turns. (Note: the above picture is for visualization purposes only, obviously the line here is not tailed thru the winch)
My thought is to turn the line around and run it forward to the windlass, which has 2 drums (gypsy's) one for chain and one for rope. I am almost always motoring as I enter our creek as the channel is narrow and by this time the sails are down, so it is not an issue to go forward to the windlass (unless the weather is really bad).
My questions are these:
Can I use the existing winch as a pulley to turn the line forward, if I wrap the line around the winch in the counter clockwise direction a half wrap? (Excuse me for not just trying this, but I am not at the boat; boat in NC, me in NJ at the moment). My thinking is that with a half wrap the wrong way the winch will just free spin. Anything wrong with doing this?
The remaining issue is that the existing line is possibly not long enough to reach all the way to the windlass. Should I use a sheet bend to tie on another length of line? Is that the strongest line joining knot? And will it pass around/thru the windlass without issues?
All thoughts or comments welcome (I know that can be dangerous on this forum, but what the heck).
Cheers.
Old 09-01-2009
Clarity
You know how problems sometimes become more clear when you try to explain them to someone else? I already can identify one issue. The line originates at the cabin roof height, but the windlass is at the deck height. The double drum is not high enough to make up that offset. So I suspect the line to the windlass will not be presented at the normal and might bind or tend to ride off the windlass. A lot depends on how much tension is on that line and I suspect it is pretty high. Also the line will probably not be to happy being drug across the cabin roof as it bends down toward the windlass.
I guess there is a reason for pulleys and such!
Cheers.
Old 09-01-2009
Wayne25's Avatar
Wayne25 is on a distinguished road
Have you thought about using a 1/2" 90*, 18v drill with a winch adapter in the chuck. I know they market a set up like this (I've seen them at boat shows) but I'm sure you could easily make the set up cheaper and to your standards.
Wayne
Rehoboth Bay/Indian River, DE
S/Y KJ, Helms 25
1976 #552
Old 09-01-2009
Going Electric
Wayne,
Thanks for the suggestion. I believe its been tried (I did not, but read it somewhere) and the portables drills just do not generate enough torque. There is a reason a windlass and motor costs around $1800.
You would need some sort of gear down mechanism between the drill and the winch. If cranking this load on the 44 were easy I would not bother with looking for a solution (I can always use the exercise). But it is a workout! And aerobic too as it goes on for about 10 minutes!
I looked into the expense of motorizing this winch, but the motor would sit at the head of the Starboard Aft Berth, which is also inconvenient.
Old 09-02-2009
Main halyard and reefing
The next mod I am considering is bringing the main halyard and a reefing line to the cockpit.
Currently the lines that come to the cockpit are the main sheet (port side), and the keel line and 2 main sail clew reef lines (all on starboard side).
Replaying one of the earlier pictures.
The double sheave block at the base of the mast brings the 2 clew reef lines to the cockpit (they both have stoppers on the boom). The main halyard comes out of the mast, thru a stopper to a mast mounted winch. If I make that a triple sheave set of blocks I could bypass the stopper on the mast and add another stopper next to the keel line stopper on the cabin roof. Then the main halyard could be lead to the starboard side of the cockpit and I can use the Harken 44 to raise the main. That Harken is only used for the keel and it is held by its stopper so after raising or lowering that winch is free.
So that would keep me in the cockpit to raise the main. But what about reefing, which is probably being done under worse conditions than raising the main. Currently I have 2 reef points and they are set by hooking an eyelet in the main onto a horn at the boom. I can envision a 2 line reefing system where a line from the boom goes thru one of the eyelets back down to the block and back to the cockpit and having a third stopper on that cabin roof.
So my question is this. If I can only bring 3 lines back to the cockpit they would be the main halyard and a pair of reefing lines for clew and tack of the mainsail. Which reef point would I want to bring the lines back for, the first or second?
My guess would be the second, because the first you probably do early, but you only go to the second reef point when you need it (perhaps?).
What are peoples thoughts on this?
Of course I could consider adding more pulleys to the Port side and perhaps bring the tack reefing lines back over there.
cheers.
Old 09-02-2009
timebandit's Avatar
timebandit is on a distinguished road
How about one of the small windlass that the smaller boats use that have all the works on the deck?
Rick
Mac 25
Copernicus
Southern California
I am not a prejudice racist sexist bigot. I just hate stupid people.
Old 09-02-2009
ottos's Avatar
Señor Member
ottos is on a distinguished road
Looking at the picture it is difficult to see how much overlap there is between the dodger and the handle, but three things come to mind, although I can see a downside to each as well.
1. Shorter winch handle - leverage won't be the same.
2. Move the clutch and winch inboard - might not line up well
3. Modify the dodger - royal PITA
Old 09-02-2009
sailortjk1's Avatar
I don't understand this statement.
With proper rigging; Turning Blocks, Deck Organizers, and Clutches, you should be able to bring as many lines back to the cockpit as necessary.
Of course there is a limit, but many more than 3 lines have been run to the cockpit on many an occasion.
There was a previous thread that discussed a lot of what you are doing, and more. See here, maybe you can find some useful information here.
http://www.sailnet.com/forums/gear-m...ging-plan.html
Courtney is My Hero
Old 09-02-2009
reefing lines
Sailor,
Thanks for the past thread, lots of useful information there. My question was more if (for the cost of adding more blocks, etc) I only brought back one set of reefing lines to the cockpit which is considered the one most used under bad weather conditions, the first reef or the second reef point?
I understand that for the cost of new hardware I can bring back more lines. If I put a triple sheave on the starboard side eye plate I can bring back the main halyard and the two tack reef lines (if the size of the sheaves can be found to match the lines). Then I would add a double sheave on the port eye plate to bring back the 2 clew reef lines. Since these lines have stoppers on the boom, there is no tension on the line once the clew is set. So they would not interfere with the boom vang as the boom swings.
But now I see a problem as there would need to be tension on the starboard lines as I would put those stoppers on the cabin roof. And they would play havoc with the boom vang when the boom swings to starboard. So I would need to move the attachment point farther fwd or closer to the mast.
As I said talking thru this to someone else helps me think thru some of the issues.
Perhaps having to go the mast to set a reef is not a bad idea as it forces me to do it early enough before the weather deteriorates to the point that I don't want to go forward.
cheers.
Old 09-03-2009
mitiempo's Avatar
You could bring all of it back to the cockpit. Means more $ for clutches of course but with the right leads its quite easy to do. In addition to mainsheet, you would need to bring two lines for each reef (tack and clew), vang, cunningham and outhaul. If you have roller furling jib it's not a problem, if not jib halyard and a jib downhaul will take care of it. I think that totals 10 + the keel lift. The winch could be moved closer to the hatch opening and the clutch already there re-aligned to suit. I don't understand why the two clew lines are led to cockpit with stoppers still mounted on boom - I would think it would work better with the clutches (stoppers) mounted closer to the winch on the cabintop.
Brian
Single handling Safety and Convenience Mods-2096615_10.jpg   Single handling Safety and Convenience Mods-lines_aft.jpg
Safety Harnesses and Tethers John Rousmaniere Learning to Sail Articles 0 05-06-1999 08:00 PM
Safety Harnesses and Tethers John Rousmaniere Seamanship Articles 0 05-06-1999 08:00 PM
Safety Harnesses and Tethers John Rousmaniere Gear and Maintenance Articles 0 05-06-1999 08:00 PM
Safety Harnesses and Tethers John Rousmaniere Cruising Articles 0 05-06-1999 08:00 PM
