Old 09-05-2009
I'd rather be sailing
labatt will become famous soon enough
Suggestion: Make sure you exercise your deck caps...
Case in point - we haven't used our pumpout deck "fill" since late February as we've always been places that we could go directly overboard. Now that we're back in inland waters we went to remove the cap and it wouldn't unscrew. We tried everything (except for heat since it's filled with methane). Finally, we pulled the whole old unit off and put a new unit in. We could then heat the old unit red hot, and only once we used a sledgehammer could we pull the cap off of it. What did we find? Apparently, it was 304 stainless, or something of the sort (it was magnetic) and the threads were completely corroded. If we had pulled it off every so often, we would have probably been OK, but we didn't. So... if you have deck fill plates that you don't use regularly - use them or lose them!
s/v "Pelican" Passport 40 #076- Finished Cruising - for the moment -
"Don't dream your life, live your dream" - Bob Bitchin'
"I'll see it when I believe it" - Me
Old 09-05-2009
mitiempo's Avatar
It probably wouldn't hurt to wipe a bit of waterproof grease on the threads if you're not going to use regularly. Also, I recently worked on the head plumbing on a 38' sportfisherman and the through hull valve wouldn't budge. The owner will replace next haulout. How many exercise through hull valves regularly on for example cockpit drains? All should be opened once a month but I bet the ones under the cockpit get closed and opened the least.
Brian
Old 09-05-2009
btrayfors will become famous soon enough btrayfors will become famous soon enough
Good advice.
I recently did a delivery on a 40' trawler which hadn't been run in at least five years. The all-bronze fuel fill caps were both frozen solid. They resisted large deck keys, hammers, PB Blaster, and all the usual stuff. It was almost a no-go, because there was no way to sound the tanks to find out if there was any fuel in them.
Finally, a punch and a lot of whacks with a 16-oz hammer got one of them to open. The other staunchly refused to budge.
Check your deck-fills often :-)
Bill
Old 09-06-2009
jjablonowski's Avatar
jjablonowski is on a distinguished road
That's why I love liquid Teflon
A little goes a long way.
TEF-GEL - Ultra safety systems - Home page
Old 09-07-2009
Omatako's Avatar
Omatako will become famous soon enough
Conversely, it's also true that deck caps don't always close the way you think they do.
We had two tanks contaminated with brine on a voyage because the O-rings had gone hard and assumed the shape of the fitting and no longer sealed, even though they were tightened down hard.
It's thus a good idea once in a while to change the O-rings and make sure that you don't get seawater leaking into your drinking water.
Arthur C. Clarke
Old 09-08-2009
roline's Avatar
Cal 9.2 SilverSwan
roline is on a distinguished road
You should be able to find VITON Orings to replace the standard NBR ones that most mfgrs use. Viton can not go as cold, only -35 F, but will go to over 400f and is more stable to fluids, ozone compression set, etc...
I replaced mine over 4 yrs ago no issues to date and I keep a spare set on board. A little silicone grease goes well with both the threads and the Orings. Easy on, easy off.....
Cal 9.2 #19 SilverSwan
Deck Washdown Systems Sue & Larry Cruising Articles 0 02-23-2004 07:00 PM
Techniques for Removing Teak Decks Sue & Larry Buying a Boat Articles 0 11-24-2003 07:00 PM
Mounting Deck Hardware Tom Wood Gear and Maintenance Articles 0 06-25-2002 08:00 PM
How to Paint Your Own Deck Don Casey Gear and Maintenance Articles 0 02-04-2002 07:00 PM
