Long Range WiFi -- Posting right now using "long range" wireless - Page 5 - SailNet Community
 1Likes
post #41 of 204 Old 10-19-2010
Good points. The NS2 seems a better solution for portability. Dan, I will be in typical anchorages and I guess no more than a mile or so from access points. I could easily attach the NS2 higher up on a stay or the mast, as high as I can reach.
The only drawback I see with the NS2 is that the poe that it comes with requires a 110V AC input. I suppose I could buy a different poe that uses a 12V input.
jwood1 is offline
post #42 of 204 Old 10-19-2010
If you're that close, go with the NS2. Valemont sells a 12VDC POE injector at wlanparts.com that is only $5.
sailingdog is offline
post #43 of 204 Old 10-19-2010
Perfect! I think I'll go with the NS2. I'll write a report when I return in Dec.
Thanks
Jerry
jwood1 is offline
post #44 of 204 Old 10-19-2010
I didn't find one by Valemont, but this one by Tycon looks good, $4.95. What do you think?
jwood1 is offline
post #45 of 204 Old 10-19-2010
richardhula's Avatar
Or.... click on image
and save a $
Richard
There's no place like 127.0.0.1
richardhula is offline
post #46 of 204 Old 10-19-2010
I prefer the ones with the jacks, since any cable damage will render the one you've picked useless. The ones with the jacks have fewer problems typically.
post #47 of 204 Old 10-19-2010
Agreed & you can't easily connect the pigtail type the wrong way around & blow up your laptops adapter.
Its horses for courses though, & remember a dollar is a dollar
Richard
post #48 of 204 Old 10-19-2010
I've found that the average user is more than able to screw up connecting a POE injector regardless of the safety precautions you take to make it idiot proof.
In the race between man and GOD where man makes something idiot-proof and GOD makes a better idiot, GOD is clearly winning. He doesn't have to replace his idiots, he just upgrades the ones he's already got...
post #49 of 204 Old 10-19-2010
Another option
Someone on Cruisers Forum is suggesting the Alpha 1 watt unit as a better option for portability, along with a higher gain antenna. They also pointed out that the NS loco 2 is only 100mw. I realize it uses a USB connection, but a 15' USB cable would allow me to put it up high enough.
So, now I'm trying to compare power and sensitivity between the NSloco 2 and an Alpha with a higher gain antenna. Any thoughts?
jwood1 is offline
post #50 of 204 Old 10-19-2010
remetau's Avatar
What kind of distance are people using these at? I can understand seeing a signal from far off, but that doesn't mean you can always get two way communication.
I use a 10db antenna connected to a Linksys router as a repeater, but for my work I use a phone card.
Don & Diana
sv Re Metau an HC33t
remetau is offline
Closed Thread
UK & Netherlands. Tacktick to launch Wireless Maxi range for large ... - BYM News (press release) NewsReader News Feeds 0 11-02-2006 05:15 AM
Light Lists, Lighthouses, and Visible Ranges Jim Sexton Seamanship Articles 0 06-19-2003 08:00 PM
Light Lists, Lighthouses, and Visible Ranges Jim Sexton Her Sailnet Articles 0 06-19-2003 08:00 PM
