Mylar sail care? - SailNet Community
post #1 of 8 Old 12-13-2002 Thread Starter
Mylar sail care?
Hi all,
I just purchased a Vanguard (Laser) Pico and it has mylar sails. Anything special about caring for mylar sails? Are they OK for high winds? Should they be folded or stored a certain way? Are they better than dacron?
Thanks in advance,
newshound is offline
post #2 of 8 Old 12-13-2002
Moderator
Jeff_H's Avatar
Mylar sail care?
First of all mylar sails should never be folded. To extend their life they should be carefully rolled so that the Battens stay parrallel to the roll. As much as posible they should be stored in a cool dark place. You should never walk or kneel on the sail of you can avoid it. You should avoid flogging the sail as much as posible.
Now then before you over react to the above, all of that advice applies to sails of any fabric that is light enough to use on a small boat.
Mylar produces a light, low stretch sail that is ideal for small boats. Today, it is a durable material. If you take proper care of it properly it will outlast conventional dacron as a racing sail material. Of course there''s the rub. Once Mylar is used up, you won''t have a ''white triangle'' left to make you think you have a sail. 8^)
Jeff_H is offline
post #3 of 8 Old 05-19-2009
Mylar Sails
I could not disagree more with the statement that Mylar sails, with proper care, will outlast dacron sails. I race a Hobie 20' with a Mylar main and it has to be replaced every 3 / 4 years (if I am lucky). They satrt to delaminate and that is the end of them
Ralph
rquesada is offline
post #4 of 8 Old 05-19-2009
tommays's Avatar
3/4 years on a race sail is SEVERAL LIFETIMES
I have and and early J24 paneled Mylar 150 (its got threads in the Mylar ?) from 1992 ? that is soft as hell and full of FUZZ still holds a good enough shape for day sailing and its gets used 2 to 3 times a week
My race 150 is a newer version of the same material and it is a PITA compare the the Pentex ones they use now BUT will stand much more abuse in terms of punctures and chafe
I am NOT liking the jump the J24 just made to Kevlar and the almost ready 3DL
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #5 of 8 Old 05-19-2009
paulk's Avatar
That is the point
Ralph
I believe Jeff's point was that mylar sails - as racing sails for a small boat- would last longer as good racing sails than a set of dacron sails would. You race with a mylar sail for 3/4 years. If you used a dacron sail, it would probably lose its optimal shape in the first season, and not perform well for racing in its second season. You'd still have a nice, white dacron triangle whose stiching might hold up for ten or more years, but guys with newer sails would pass you. We sailed a Soling for many years. In order to stay competitive we needed a new dacron jib every season, and a new main every other season. We ended up with enough dacron to wrap a house. We all agreeement that mylar sails delaminate and disintigrate after losing their shape. (Happened to me once during a race - we ran out of ripstop and started using duct tape.) The question is how long mylar holds its racing shape compared to dacron. Your answer: 3/ 4 years -- shows that mylar lasts about 3 or 4 times longer than dacron.
paulk is offline
post #6 of 8 Old 05-20-2009
Cal 9.2 SilverSwan
roline's Avatar
My 525 came with a dacron-mylar laminated light 155. It was old 4-5 yrs of use. While I had it up, the wind piped up to 8 knots and the sail started to delaminate and streach. The sail should of been able to stand up to 8 knots, but it was 4-5- yrs old. My Cal 9.2 has a mylar carbon fibre laminate 135 that has seen lots of use and is getting a little frayed on the very edges of the panels but still has good shape and no serious delamination. It powers the boat well in 14-22knots. Its over 5 yrs old. The newer materials are more durable than the first laminated mylar versions and minimize flogging the sails, the leach was the first to go.
roline is offline
post #7 of 8 Old 05-20-2009
I don't discuss my member
zz4gta's Avatar
For a small boat, you have no reason NOT to roll your sails. Big PVC pipe on the side of the trailer will hold the sails nicely while in transit. Rolling sails is the best way to take care of them, period. It's just a royal PITA to store something 15' long and 1' in diameter.
Second best is flaking them, only do this if you don't have the room to store them rolled. Flaking is just loosly folding the sail like a fan or an accordian. Then loosly roll the 'fan' and put into a large bag.
Keep your mylar dry, mylar laminates LOVE mildew. On a Laser, bring a towel to wipe them off if they get rain or sea spray on em before you flake/roll.
Merit 25 # 764 "Audrey"
zz4gta is offline
post #8 of 8 Old 05-20-2009
blt2ski's Avatar
A lot of folks with smaller boats like the different Vanguard boats will have "Race" and "practice" sails. The race sails being the mylar, the practice being a basic dacron.
But as mentioned, the newer mylar sails are being made much better than older one, will hold there shape way longer in the terms of hrs, times used etc than dacron before they "go"! 3 of my 6 sails for my 30' Jeanneau are mylar based, one is a dac/mylar 110, 2 are nylon based, ie a spin and a 130 drifter reacher for winds under 5-6 knots.
Marty
Now that I posted this, I am realizing the OP and Jeffs posts are from 2002!
She drives me boat,
I drives me dinghy!
blt2ski is offline
Heavy weather sailing sailorfrank Learning to Sail 26 09-10-2013 07:32 PM
Windward performance deseely General Discussion (sailing related) 21 04-01-2012 03:42 PM
Sloop, Cutter or Ketch jsgsail Boat Review and Purchase Forum 17 12-26-2008 03:47 PM
Ketch/Yawl Handling svsymphony Seamanship & Navigation 19 07-05-2008 02:19 AM
Traveler usage? Humpwalker Seamanship & Navigation 22 02-17-2007 11:54 AM
