Deck paint/ epoxy??? - Page 2 - SailNet Community
post #11 of 30 Old 09-17-2009
Are you handy [very handy] with a paint brush? or a spray gun? If not please consider prepping and priming [any 2 part epoxy will work] yourself, then get a specialist for topcoating. Unless your standards are not very high, a deck and cabin house paint job is no place for beginners. A roll and tip job can approach spray quality especially if done under cover-should not require haulout ,which certainly spray work would at most marinas.
georgefmys is offline
post #12 of 30 Old 09-18-2009 Thread Starter
clueless
Me and a gun go waaayyy back.. But a brush , well not so much.
But, my wife is an art teacher and has done murals the size of a building so i think she can cover the brush part...lol
Besides , it sounds like fun..
dieselboy is offline
post #13 of 30 Old 09-23-2009 Thread Starter
clueless
Ok, so i am about to put in an order and i am being recommend to go not with the Interlux perfection but with another brand.
This is what i am being recommended to use?
Any feed back from any one here? Its twice the price?
ALEXSEALŽ Premium Topcoat 501 is a two component, polyurethane-based coating, designed for exterior and interior applications. ALEXSEALŽ Premium Topcoat 501 has a high gloss wet look which provides superior distinction of image. This product has been specifically developed for the yacht industry.
Welcome to GCM Distributor
In a word ...help?
They say" its a 8 year life span vrs the interlux which is 3.. How true that is i have no clue any one here have some in site to it?
post #14 of 30 Old 09-23-2009
mitiempo's Avatar
I believe the 8 year lifespan which you should also get from Interlux Perfection but not from Interlux Brightside which is a one part poly and will probably last 3-4 years.
Brian
mitiempo is offline
post #15 of 30 Old 09-23-2009 Thread Starter
clueless
Down here sun is the killer.. We have 10 months of intense sun and 100 degrees for at least 3 months out of the year. Hence why my gell coat looks so bad. Neglect and lots of sun.
post #16 of 30 Old 09-23-2009
I can't reMember
ezatsea's Avatar
I'd stay away from the one-part. My experience with it was in the tropics and it just doesn't hold up to the sun. Not familiar with the ALEXSEAL products but I've had a lot of experience with Awlgrip, Sterling and Imron in commercial settings. According to the link above the ALEXSEAL product seems to be quite similar.
Ed
s/v casa chica
S&S Swan 43
Keep the boat IN the water,
keep the water OUT of the boat.
ezatsea is offline
post #17 of 30 Old 09-25-2009
Hi Thought I would chime in here. I had a yacht restoration and refinishing bussiness for more then 15 years. I have worked on boats from 8 foot dinghies to meg Yachts of 120 foot.
Are you planning on painting the cabin ad The Deck? or just your non skid? Brushing any good quality LP takes time. The Sterling paint website has some good information Painting. They relate to any 2 part LP paint.
If you plan to use a brush here are some useful tips One thing I recommend is Take your project in sections. Plan out an area that you can tape off. Such as rear of cabin and do that section. Then Port side and Starboard side. The best method is to use a foam roller and have a 2nd Pearson follow and tip out the pant with a quality brush. When brushing you will most likely have to do 2 or 3 coats. Make sure this is done with in the limits of what the Paint manufacturer recommends. Other wise you will have to lightly sand between coat with 220 sand paper. Plan your tape lines so that they are not too visible when you are finished. Now if you plan to spray you should be able to do all the cabin and decks at once. Prep is the key to successful application. after the main area is cured back tape with a high quality fine line tape for your nonskid make sure the edge of the tape is pressed down tight. paint creep really makes a job look amateurish. The nonstop is best done with a roller and brush. ad some nonskid beads to your paint. Mix the paint often so beads stay suspended. They will layout in a nice even pattern as the paint cures. Good luck and even when doing this outside wear a good respirator. On a side note bugs seem to be attracted to the smell of LP paints. Try and find someplace that is as bug free as possible.
I once did the finish work on a 45 foot sloop that was being built inland. All around the area where Farms, pastures and cows ! I waited untill I had a calm day with little wind and shot the hull. Well as luck would have it, a slight breeze picked up and shifter from the nearest pasture. Before the paint cured there were millions of flies all over the port side. It looked like the port side hull had grown a living beard. I can laugh about it now. At the time It wasn't so funny.
Artz is offline
post #18 of 30 Old 09-25-2009
Painting
Artz is offline
post #19 of 30 Old 09-27-2009 Thread Starter
clueless
I bet that was not funny. But, i still would like to of seen it.
post #20 of 30 Old 09-27-2009 Thread Starter
clueless
I bet that was not funny. But, i still would like to of seen it.. the beard boat.
Installing Treadmaster Nonskid Sue & Larry Gear and Maintenance Articles 0 07-11-2004 09:00 PM
Installing Treadmaster Nonskid Sue & Larry Cruising Articles 0 07-11-2004 09:00 PM
Techniques for Removing Teak Decks Sue & Larry Buying a Boat Articles 0 11-24-2003 08:00 PM
How to Paint Your Own Deck Don Casey Gear and Maintenance Articles 0 02-04-2002 08:00 PM
Renewing the Nonskid Don Casey Gear and Maintenance Articles 0 03-31-1999 08:00 PM
