09-15-2009
Cal 9.2 SilverSwan
You will have to check the sheet lead block position and how the foot of the sail clears the stanchions ans sweeps the deck. I did a CAD model of my Cal 9.2 so I could draw the sail and calculate the lead position being a straight line from the center of the luff through the clew. I wanted to be able to move the lead back to depower and forward to power up the sail. This helps to increase the apparent wind usage range of the sail as long as I don't blow it out.
I raised the light #1 on by Santana525 by 8" and this helped to automatically skirt the foot when tacking. It was hanging up on the stanchion. The lead still had enough adjustment.
I've bought several racing seconds and they work great for cruising and I even placed second in the spring series. One find was a carbon fiber/pentex mylar laminate for $300 and it works great in 12 to 19 knots of apparent air. I also found a light #1, 150% I put it on its own halyard so I could do a quick hoist and drop. Works great up to 5 knots, then the 155% is used.
Perfect they are not for performance, but perfect they be from price.
Just be careful that you don't buy a blown out rag. Most reputable used sail dealers will allow for a hoist and check of sail shape with a money back less shipping.
Cal 9.2 #19 SilverSwan
