09-16-2009
Assuming no water has been allowed to accumulate inside the hull, it is likely as dry as you'll ever get it. You could use a moisture meter but it can be quite misleading, particularly if you don't know how to use it properly and have no prior reading with which to compare current results, many lack any ability to reproduce results and generally it is a wasteful expense esp if you only need it once.
A much more reasonable approach in your case is simply tape a one ft square piece of plastic tightly at a few places on the bottom, wait a couple of (dry) days and see if any condensation accumulates between the plastic and the hull.
If not, no problem.
