09-16-2009
Alright guess I was two fast on the ask button again, I just foud this:
D, DUAL OUTPUT MODELS: Each terminal provides proper charging to a separate battery or bank. Each output terminal can charge up to the alternators max rating but both terminals together can not exceed the alternators maximum rating. Remember that the current (amps) flows to the battery with the least resistance or greatest need first. Once equal, both batteries will receive about the same charge. The regulator looks at one battery only, so we recommend that the house bank be used for sensing. Bridging or connecting the two terminals makes the output single. DO NOT OPERATE without each main output terminal connected to a battery or bridged. To charge a third or fourth separate battery, a two bank isolator must be installed on each output terminal. For extended storage periods, disconnect the alternator from the batteries. The voltage equalization circuit in the alternator allows a small (milli amp) flow between the batteries to prevent surface voltage buildup.
http://www.balmar.net/PDF/2000%20Alt...r%20Manual.pdf
Anyone has an any experience with a similar system ?
