redoing decks - Page 2 - SailNet Community
post #11 of 13 Old 02-14-2010
I'd highly recommend you read this post on cored GRP construction that I wrote. It talks about the pros and cons of the different core materials, as well as the pros and cons of some of the materials used in GRP construction—like Carbon Fiber, Kevlar, and fiberglass.
I'd also point out that re-coring a deck from the top is generally going to be far easier and faster than trying to do so from underneath, since gravity is working for you and you're far less likely to layup the repair with voids.
Also, try and make solid fiberglass pads for the areas you will be mounting deck hardware. If you can't do that, at least make sure you properly rout the core material out and pot the holes with thickened epoxy to protect the new core from water intrusion.
Originally Posted by jeanfrancoissavard View Post
I think i will be going with wood instead of foam ...I prefer the strengh, feel ill be more confortable working with wood... im not sure if ill use balsa or plywood. Any suggestion?
sailingdog is offline
post #12 of 13 Old 02-14-2010
catamount's Avatar
Originally Posted by tommays View Post
catamount
i was looking forward to learning from you pictures but there seem to have broken links today
My hosting provider seems to be having some problems this morning. Perhaps bandwidth issues related to Vancouver Olympics because I think the server my site is running on may be in that area? All I can suggest is to check back later.
Peterson 34 GREYHAWK, West Boothbay Harbor, Maine
, a new voice for ocean conservation
catamount is offline
post #13 of 13 Old 02-14-2010
Learning the HARD way...
eherlihy's Avatar
Definitely check out Tim Lackey's restoration of Glissando, pointed to by mitiempo. Also, West has a well written article on repairing the Balsa Core here.
For material, if you would like to try the material that the US Navy uses (not affected by moisture, has better structural properties than balsa, but weighs a little more), send me a PM, and I'll put you in touch with the manufacturer.
eherlihy is online now
T-4 years to 14 month sail...and buying Livia Boat Review and Purchase Forum 43 03-10-2007 07:52 AM
Techniques for Removing Teak Decks Sue & Larry Buying a Boat Articles 0 11-24-2003 07:00 PM
Homemade Teak Decks, Part Two SailNet Gear and Maintenance Articles 0 10-02-2002 08:00 PM
Homemade Teak Decks SailNet Gear and Maintenance Articles 0 08-01-2002 08:00 PM
Cleaning Fiberglass Hulls and Decks Sue & Larry Her Sailnet Articles 0 03-07-2002 07:00 PM
