Marelon and PVC - SailNet Community
Blogs
Old 09-19-2009
Jmac62 is on a distinguished road
Marelon and PVC
I am replacing some thru-hulls and removing the old seacocks from the head that no longer exists. My plan is to use marelon thru-hulls and then to cap them. Since there are no marelon caps (not made) I was thinking pvc. Bronze is too expensive and I want to keep the thru-hulls option without patching the holes.
Old 09-19-2009
k1vsk will become famous soon enough
Patch the holes, use bronze seacocks, sink the boat - your choice. Just curious - what is "too expensive" when compared with the loss of a
a boat, the liability of removal of a sunken boat, environmental liability, etc...?
Old 09-19-2009
Maine Sail's Avatar
If you want to cap thru-hulls then use a Marelon valve (NOT PVC) on a Marelon thru-hull and close the valve. The safest choice is to patch the holes with a tapered repair. It is not a good idea to mix different materials below the waterline that have differnt thermal expansion coefficients such as Marelon & PVC or Marelon & bronze. PVC should be avoided at all costs for below waterline use as it fractures easily and is not a reinforced plastic product. I have personally seen a Marelon valve cracked that had been threaded onto a bronze thru-hull..
If you MUST cap the Marelon thru-hulls a bronze cap is a far better idea than PVC but it is still not a good idea due to mis-matched threads. If you must mix Marelon & bronze the male Marelon should thread into the female bronze. Avoid threading male bronze into female Marelon..
______
-Maine Sail / CS-36T
Old 09-19-2009
tager's Avatar
tager is on a distinguished road
NPT caps are not that expensive in bronze...
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
