09-21-2009
Gadabout the Sound
Hi there,
I've had success replacing transducer cable with shielded microphone cable from a music shop (assuming your brand of depth finder uses the simple 3-strand pos/neg/ground cable) at only $1 per foot. I just wrapped tin foil and electrical tape around each cable's splice (solder the wires for best effect) and then again around the bundle of cables. The braided shielding in the mic cable acts as the ground wire, so you just have to twist it up.
Although, I wonder how applicable this is to your situation, since it sounds like you have plenty of wire. Was your splice itself shielded? Can you tell if there's any water damage or corrosion in the existing wire?
Good luck!
