Old 09-21-2009
johnnyandjebus's Avatar
johnnyandjebus is on a distinguished road
rock climbing harness as a sailing harness
Hello all
I will be installing jacklines on my boat this fall and wonder what people think about using a rock climbing harness as a sailing harness? The main difference between the two being the sailing harness is a chest/over the shoulders style of harness while the rock climbing harness is awaist stlye of harness. I ask becuase I already own a climbing harness but not a sailing harness.
Thanks,
John
Old 09-21-2009
Allanbc's Avatar
Allanbc is on a distinguished road
This is a very bad idea. The reason for the attachment point at the chest on a sailing harness is so that you will remain upright if you go over the side. With a low attachment point like on a climbing harness, you can spin around and end up upside down in the water. There is not much air to breathe when you are upside down in the water.
"When in command, command." -- Admiral Nimitz
Difference between a power boater and a sailor out on the water: A power boater is going some place special, a sailor is already there.
s/v Zotz 1981 Pearson 365 Ketch Hull #375
Old 09-21-2009
Flotsam with attitude
Naughtylus is on a distinguished road
If you mean is the climbing harness suitable for getting you up the mast, then I would say no problem.
I regularly use my rock climbing harness for going up the mast, and I have no problems whatever with it. I have found it excellent and secure for this purpose.
I agree with Allanbc that it is NOT suitable as a replacement for a safety harness, to be attached to your safety lines, for exactly the same reason he states.
Aspire to inspire before you expire !
Old 09-21-2009
merlin2375's Avatar
*starboard*
merlin2375 will become famous soon enough
/\/\ +1, not a suitable replacement. Would also probably get pretty annoying to move around the deck efficiently in a rock climbing harness.
I sail.
Old 09-22-2009
Thanks for the replies, I suspected as much so far as falling over boat head first.
So my next question is...
Currently I have on board the traditional vest style life jackets, any thoughts on the integrated inflatable pfd/harness vs. a separate harness and inflatable style life jacket?
Thanks again for the responses.
John
Old 09-22-2009
S/V Lilo, Islander 32
IslanderGuy is on a distinguished road
I KNOW others will disagree, but I personally really like the integrated harness and inflatable PFD. In the short time before I purchased mine I had a seperate harness and standard PFD, both which came with the boat. I found it annoying to have to take of the PFD to but on the harness, then put the PFD back on as conditions are deteriorating. I know myself, and figured if I already have the harness on as a part of the PFD, I am much more likely to pick up the tether and clip in when needed. If I need to go forward for a minute and things are marginal, I would be more likely to go without the harness then to take the time to take off the PFD, put on the harness, then put on the PFD again.
I know many people will argue that wearing both is redundant and unnecessary, and it very well may be, but I like the added security myself. If for some reason I am hanging off the side by the harness and need to un-clip to get back on board or something, I like knowing that I will have the PFD as well if it is needed. Paranoid may be, but since they are integrated it is no big deal.
However, I currently sail in cool climates where wearing the PFD all the time is no big deal. I do still have the separate harness and could see using it alone on hot days, especially if the weather is good, but I am harnessed in since I am the only one on deck... we will see when that day comes
S/V Lilo
1964 Islander 32
Saint Helens, OR
Old 09-22-2009
zz4gta's Avatar
I don't discuss my member
zz4gta is on a distinguished road
I have an integral harness on my PFD and really like it. Not the best for bouy racing, D rings get caught on cleats, but I've been otherwise happy with it.
Merit 25 # 764 "Audrey"
Old 09-22-2009
pdqaltair's Avatar
pdqaltair is on a distinguished road
Nix on the rock climbing harness, but keep the wire gate biners!
Standard climbing biners can't handle the salt and will quickly seize; I trashed quite a few retired climbing biners this way, mostly on utility/unimportant uses.
However, the wire gate biners do quite well, are as strong as the SS biners, are much cheaper, and are much less likely to put a hole in your gel-coat.
(when asked how he reached the starting holds on a difficult rock climbing problem that clearly favored taller climbers - he was perhaps 5'5")
"Well, I just climb up to them."
by Joe Brown, English rock climber
Learning to Share PracticalSailor Learning to Sail Articles 14 09-21-2011 02:28 AM
Rock Star Recalls Scary Sailing Voyage tondelayo29 Seamanship 8 06-18-2010 09:12 AM
Daniels Predicts Smooth Sailing On Election Day (KTHV Little Rock) NewsReader News Feeds 0 11-03-2006 01:15 PM
Great Books for Beginners Mark Matthews Gear and Maintenance Articles 0 01-27-2000 07:00 PM
