09-23-2009
You have what appears to be an older CDI furler. There is a headstay and likely a turnbuckle inside. You do have to disassemble the drum to access it.
In the photos, it looks as though there is no tension on the stay at all. It sounds like your headstay has broken inside the furler.
I would recommend that you lead some halyards forward to hold the mast up and call a professional rigger. Immediately.
Ron Paul 2012
"wikijar"
