Old 09-25-2009
LarryandSusanMacDonald's Avatar
SaltwaterSuzi/CapnLarry
LarryandSusanMacDonald will become famous soon enough
Running diesel to Charge Batteries
This has probably been talked about, but I'm too lazy to look it up.
Today, we started the diesel engine again to charge up the batteries. Saltwater Suzi (an order of magnitude smarter than I) softly asked, "I thought we bought the Honda Generator to do that."
I answered, "It's a hassle and makes too much noise."
She countered, "I thought you told me that it wasn't good for the diesel to run it just to charge the batteries."
I pondered a response that wasn't going to get me into a lot of hot water, and failing same said, "I've heard that, too. But I can't imagine why."
And I can't. So I ask, is it so and if so why? Not too technical please, I can't afford to risk spraining my brain again. (Had a thought the other day and it laid me up for hours.)
As usual, thanks in advance for your input.
Saltwater Suzi and Cap'n Larry
"A sailboat is a fickle mistress. You’ve got to buy her things. You’ve got to understand everything about her. What you don’t know she’ll use against you." -Captain Larry
Old 09-25-2009
deniseO30's Avatar
Lies about her age
Now if you had even 10watts of solar the batteries would stay topped off. so there's a 3rd option . giggles
Old 09-25-2009
priscilla's Avatar
priscilla is on a distinguished road
The engine is just happy to be running....it likes a little load and your alternator provides that.
Priscilla
Old 09-25-2009
GeorgeB is on a distinguished road
You have a Morgan 41? What size is your engine and how big is your alternator? I imagine that your engine is somewhere around 50 horse? A 120 amp alternator is barely going to put a load on the engine. Over time, you run the risk of the exhaust elbow “coking up” with un burnt hydrocarbons because there isn’t sufficient pressure to blow them out. They build up over time, restricting the exhaust flow, resulting in higher pressures and temperatures. Ultimately causing elbow cracking or burn-through. Diesels are happiest running WOT. Is your alternator an externally regulated one?
Old 09-25-2009
JohnRPollard's Avatar
Moderator
For that kind of money, you could have avoided all the noise and hassle and bought a few linear miles of extension cord.
Old 09-25-2009
BarryL's Avatar
BarryL is on a distinguished road
Hello,
Engines, especially older engines, do not like to idle. The engine does not get hot enough to burn off impurities in the oil. The fuel injection is not designed to be very accurate at idle, so the fuel burn is not complete and the exhaust will be sooty. This leads to build up in the exhaust system.
In short, diesels like to be run at cruising RPM and not idle speed. IMHO, if you need to run the engine to charge batts, put the boat in gear. That will put more load on the engine.
Barry
Barry Lenoble
Day To Remember, 1986 O'day 35
Mt. Sinai, NY
Old 09-25-2009
Denise:
I guess I didn't mention that we are live-aboard cruisers. 10 watts is akin to spitting in the ocean. We've got computer, microwave, coffeemaker, TV, etc. all the comforts of home.
Priscilla,
I like your answer best (for my purposes, at least, it keeps me out of trouble with Suzi)
GeorgeB.
Westerbeke 55B (about 4 years old 853 hours) with 170amp alternator, set to 100 amp output max with Link 2000r. We run at about 1400 rpm when charging batts - it runs about the same temp (~180) when we are moving the boat as when just charging batteries.
John,
Got it used - 2000 watt for only $500. I am the Frugal Mariner, you know!
So am I O.K. here? Can I run the diesel or should I go with Mr. Noisy?
Old 09-25-2009
SteveInMD is on a distinguished road
Here's a short article on the subject...
Bore glazing
Old 09-25-2009
Moderator
John,
Yeah, but the extension cords are so much quieter. And they can double as spare standing rigging in a pinch.
Old 09-25-2009
negrini is on a distinguished road
Send a message via AIM to negrini Send a message via Yahoo to negrini Send a message via Skype™ to negrini
Barry, me too were educated on this, including specialists observating same advice. Steve, I had red this article before, wich corroborate to people like Nigel Calder. What I couldn't explain is in a heavy traffic city like here, people spend (an average) 3 hours per day in traffic, mostly iddling the engines, but diesel cars/van/truck are still very reputable for longevity and reliability. I can understand the efficiency math (running a big beast to power tinny 500W to your DC system), where oversized generators are wasting more fuel per Watt, if compared to smaller unities) but cannot understand why marine diesels wear faster if iddling, copared to automtive diesels iddling. Should marine learn a thing or two from automotive industry ?
Nave Rara
Beneteau Oceanis 43
Paralleling Batteries dave.verry Gear & Maintenance 79 11-27-2006 11:19 AM
house batteries seac Gear & Maintenance 9 08-23-2004 04:28 AM
