Slowly but surly - SailNet Community
post #1 of 7 Old 09-26-2009 Thread Starter
Handsome devil
Stillraining's Avatar
Slowly but surly
Here is an update... and as of so far the current progress on my refit project.
A before picture of my Perkins 4-154..The only real reason it came out was to facilitate all the other things needing done to satisfy the insurance co. so the yard wanted it and the gen set out of the boat..
I took advantage of that and went through the head and also sand blasted it to bear metal..painted with a rust encapsulator just in case..and then with high temp engine enamel...a couple pictures as it sits in the boat right now...I wanted to paint the beds with white epoxy but I got hung up at work the week they decided to re instill the engine so I will now have to worm my way in there to get it done...all hoses you see will be 100% replaced with new...as is the sound barrier and wiring.
I watched another Summer come and go with out so much as getting the hull wet but its getting closer.
"Go Simple...Go Large"
Relationships are everything to me..everything else in life are just tools to enhance them.
The purchase price of a boat is just the admittance fee to the dance...you still have to spend money on the girl...so court one with something going for her with pleasing and desirable character traits others desire as well... or you could find yourself in a disillusioned relationship contemplating an expensive divorce.
Stillraining is offline
post #2 of 7 Old 09-26-2009
The Elephant
smackdaddy's Avatar
WOW still - that looks beautiful. Nice work.
smackdaddy is online now
post #3 of 7 Old 09-26-2009
the pointy end is the bow
erps's Avatar
Geez Scott!
How are you going to tell it's a boat motor without the rust on it? Looks great. So tell me more about that black paint. Is it a fancy primer? Also, what did you use to get the motor out of the boat and on to the truck? A-frame? Your boom? Just wondering for the day I have to do it.
Ray
S.V. Nikko
1983 Fraser 41
La Conner, WA
erps is offline
post #4 of 7 Old 09-27-2009 Thread Starter
Handsome devil
Thanks Smack.
LOL Ray...
After a discussion in a thread a while back and the differing opinions as to what was the best or better then others I decided to go my own way and use Eastwood's products as I have been very happy with them in the past. The paint I used is this
Black Rust Encapsulator Kit
I have spray equipment so I wanted something thinabal and it being Lacquer based worked out perfectly as well as their enamel based 650 degree rated engine paint....Being an auto paint supplier you will not find marine engine colors through them but I'm not that meticulous for something like this...especially since I was doing a complete repaint and not a touch up.
As far as pulling and resetting we used the yard crane...being a center cockpit they made a special "C" spreader that lowered down into the companionway but extended back beneath it ...I actually removed the boom completely off the mast to facilitate this and also so as not to get it dinged up as it was just repainted last year.
Here is another picture with the new tranny installed.
post #5 of 7 Old 09-27-2009 Thread Starter
Handsome devil
I also reworked my heat exchanger as they wanted 3K for a new one... yes I did find one... but at that price they can keep it..so we cut and welded on mine and I resurfaced it on my edge sander in my shop..it turned out almost good as new... as did a several cast iron parts that were corroded and leaking..they both have perfectly flat and true sealing surfaces now.
post #6 of 7 Old 09-27-2009
Moderator
JohnRPollard's Avatar
Scott,
Nice work!! There's just something about a nice clean engine room....
I hope you and the family will be out on the water again soon.
JohnRPollard is offline
post #7 of 7 Old 09-27-2009
Valiente's Avatar
Good job, Scott.
I'm in the same place, but we'll see if I go new engine or rebuild as I'm still sourcing parts.
Can't sleep? Read my countdown to voyaging blog @
Valiente is offline
USA. Volvo Ocean Race. ABN AMRO parked, movistar moving slowly @ BYM Sailing News NewsReader News Feeds 0 04-17-2006 04:15 PM
movistar slowly gaining on ABN AMRO ONE @ Sail World UK NewsReader News Feeds 0 04-13-2006 08:15 AM
