Old 10-01-2009
stpetersburgsailor
Guest
Posts: n/a
bottom paint 101
any rules for gallons per foot on a sailboat?
any brands u lads prefer
say a 25' simple coastal sail vessel, sleeps 2 or 3
how often do u re-coat
this vessel seems in great shape, a bit faded on the lower hull however
types of sandpaper, grit # ?
hand sanding? if it is not in tough shape...
any other tips much appreciated
Old 10-01-2009
tager's Avatar
tager is on a distinguished road
A gallon will do her 2 or 3 times at least. I got a gallon at west marine for SIX dollars. So keep your eyes open! I just scrubbed with a wire brush, not sure if that is "correct". Adhesion has been crappy.
Old 10-01-2009
MSN2Travelers's Avatar
Badger Sailor
MSN2Travelers is on a distinguished road
Just did mine this spring (26 footer). One gallon was good for two coats.
Surface prep was with 80 grit on a hand held 5" random orbital sander.
How often depends on the type of anti-fouling paint you use and the water conditions where she is sailed/stored.
I used a hard multi-year paint for trailerable boats. This applied over a two-part epoxy barrier coat.
All this assumes the hull does not have any blister problems.
Paul
`99 Beneteau Oceanis 352, #282 Witchcraft
Madison/Milwaukee, WI
Sailing Lake Michigan and the Great Lakes
Old 10-01-2009
stpetersburgsailor
Guest
Posts: n/a
thanks Paul!
any thoughts on dry time before she goes back in the salt soup?
Old 10-01-2009
nickmerc's Avatar
nickmerc is on a distinguished road
Take a look at the manufacturer's website for the paint you want. It varies based on temp, humidity, paint type, etc.
________
YamyNika live
Old 10-01-2009
fordo is on a distinguished road
Careful about the sanding. The dust is highly toxic and a pollutant. You should wear protective clothing and a mask and use a vacuum recovery on the sander. I have always wet sanded (to prevent dust) and allowed the water to collect (and dry) in a plastic sheet under the keel. Then I throw the sheet away. New regulations covering N.J. marinas may prevent this, however.
You should get two coats out of a gallon on your boat.
Old 10-01-2009
CaptKermie's Avatar
CaptKermie is on a distinguished road
Ablative for trailerables
I also just did my 26 footer last spring (May). Four coats from two gallons of epoxy barrier then the Antifouling. I got two complete coats from a gallon of CSC Ablative and a third partial around the water line , bow and stern. There wasn't quite enough for a third full coat so I did the critical areas. For Trailerables it was recommended that I use an ablative because it stops working out of the water then starts again when put back in the water whereas the hard paint stops working altogether if kept out of the water for any length of time.
Old 10-02-2009
cruising all I can
joethecobbler is on a distinguished road
Just completed a bottom job on a 32' in tiusville,fl. completely removed all bottom paint to the jelcoat. Repaired all/any damaged spots,removed 2 through hull transducers( to be replaced w/ shoot-thru-hull type).4 epoxy barrier coats and 3 coats of ablative Pettit unepoxy I pd $76 a gallon used 2 gallons rolled and brushed where necesary. The prep , I believe is the key. I finish sanded w/80 grit w/ an air power orbital. about 40 disks and 30 hrs.
THe last bottom job lasted 2-3 years but I was moving for the first 2 or so. I find if I anchor in filthy water (halifax river for example) I get more growth.
I don't believe the higher priced ablative paints offer much more for the extra money. and if your scraping on a regular basis your probably scraping off most of the bottom paint (ablative) anyway.
If my boat was trailerable I'd probably just take it to a carwash occasionally and use the cheapest paint I could buy.
Old 10-02-2009
tommays's Avatar
When i used micron Fiberglass Bottomkote® with Irgarol a gallon scrubbed off in one season and it was like a snow storm every cleaning and the boat was pretty much back to barrier coat when hauled
This Season i used Micron Extra with Biolux and its much harder and while you see a bit in the water during cleaning it has held up far better
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
The Bottom Paint Blues Don Casey Gear and Maintenance Articles 0 06-22-2003 08:00 PM
Sick Bottom Paint? kmeeks Gear & Maintenance 4 05-16-2003 02:20 PM
How to Paint Your Own Deck Don Casey Gear and Maintenance Articles 0 02-04-2002 07:00 PM
Bottom Paint Compatibility Dan Dickison Gear and Maintenance Articles 0 01-24-2001 07:00 PM
Paint the Bottom Yourself Tom Wood Gear and Maintenance Articles 0 03-09-1999 07:00 PM
