composting toilet report - Page 30 - SailNet Community
 45Likes
post #291 of 443 Old 01-08-2012
Originally Posted by RobGallagher View Post
That's pretty neat! The tanks a bit small, but with the availability of pump out boats it might be a good alternative.
Now I wonder if I can take the contents home and compost it ...
As long as you haven't used the chemicals, yes you could, but it would be a pretty disgusting proposition though.
If you think dealing with a mostly dry, sawdust covered plastic pail of virtually odorless waste is nasty, wait till you start dealing with anaerobically active liquid waste.
I would recommend that you stick with the pump out.
And yes, I know you were only poking fun.
knothead is offline
post #292 of 443 Old 01-08-2012
tommays's Avatar
Due to the LOW amount of flush water because it is a direct deposit device with the poop NOT traveling to a tank it is BIG at 9.5 gallons
We are pretty good about timing are deposits and while we did have it pumped twice in 2011 we cold have gotten by with once
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #293 of 443 Old 01-08-2012
davidpm's Avatar
Originally Posted by knothead View Post
. And it won't be any more dangerous than all the diapers that end up there.
Good point.
The way I see it the volume is so low it shouldn't matter.
davidpm is offline
post #294 of 443 Old 01-08-2012
Tommays, I don't understand what you are saying there. Where does the poop go if not into the tank?
The manual says it uses an average of one quart per flush. If you add in the urine and the solids. The way I figure it, you will probably get around thirty uses before having to pump out. Depending on how many people, especially females are using it, that's pretty good.
I would certainly choose a system that had it's own self contained tank before I ever went back to a traditional set up. If it smells anything like a port-a-potty though, I wouldn't want anything to do with it.
knothead is offline
post #295 of 443 Old 01-08-2012
Closet Powerboater
MedSailor's Avatar
Interesting device. Probably a good choice for smaller boats who don't want to go the composting route. An EXCELLENT device when matched to a maceratior/overboard discharge for Canadian boats. Most canadian boats of any vintage are direct-overboard flush only, which in most areas is totally reasonable form an environmental point of view, but a unit like this would allow you to keep the stuff out of the water while travelling by the oyster farms of Desolation Sound, or in the crowded low-flow harbors and anchorages.
As long as it has some flush water it might smell less than a porta-pottie, but on the other hand, it'll be an anerobic tank and every time you make a deposit, I would expect smell unless you use chemical warfare.
As for the previous comments about there being no way to dispose of composing toilet waste, the answer is to put it in the trash. I like Knothead's comparison to diapers in the trash. There was also some hysteria about the dangers if someone's dog got into the trash, or the poor trash handler etc, and to those I would say that trash is rife with bacteria. That raw turkey you threw out 3 days ago is now crawling with salmonella and shigella. The cat litter is full of e-coli and even toxoplasmosis and yet sanitation workers and those who rifle through trash seem to do okay.... The Nature's head has a neat design feature whereby a yard-waste trash bag fits snugly over the lower part of the toilet. Turn it over and it all goes into the bag. No touching of poo required. Though I still wash my hands afterwards for good measure.
Medsailor
PS Knothead, I can't speak much to the question of development of immune systems as a child because there isn't enough good evidence one way or the other that infections "strengthen" the immune system. What I can tell you is that the immune system is largely developed before adolescence and doesn't change much as an adult. Many of us who go into healthcare fields suddenly find that we never get sick anymore and some (usually not the providers because we're supposed to know better) attribute it to "a stronger immune system" when really the evidence shows it's because we wash our hands obsessively.
For further reading related to your question, check out "The Hygiene Hypothesis." A mature, but unproven, hypothesis that allergic diseases specifically are caused by the lack of parasite exposure in the developed world. When reading about this topic or ANYTHING MEDICAL please PLEASE skip right over Wikipedia. ANY website is better than they are on medical topics.
MikeOReilly likes this.
MedSailor is offline
post #296 of 443 Old 01-08-2012
tommays's Avatar
The poop goes into the tank and travels 12" BUT does NOT have to travel down a hose to a tank and use a bunch of water getting it there which cuts out most if not all the places systems get smells from
To be perfectly honest if you leave the freshwater OFF and people are just peeing you can turn on the water and rinse the bowl at the end of the day
If you leave it on it takes a TINY amount of water to flush pee and is for sure the lowest water use unit of its type
Tommays
Northport NY
tommays is offline
post #297 of 443 Old 01-08-2012
The Bears two cents worth....
Would be very interested in poll, and hats off for a great article Genieskip! Exactly the kind of information needed for "an informed desision". The idea of getting rid of that 10 gal. holding tank and all the extra plumbing on my 24' boat is fantasicly beautiful. I don't care what the factory rep's say after a couple of years those poly tanks smell. And the idea of a dorade vent instead of a 1 1/2" hole in the hull is even better.
Run the poll, get more input, get more info, feedback. Faster,S..Dad, this is good, get on it.
Redthe Bear
RedtheBear is offline
post #298 of 443 Old 01-08-2012
Mobnets's Avatar
We were ready to jump to a composting toilet at this time last year. Saw the Airhead and Nature's Head at Strictly Sail Chicago and thought this was perfect. No qualms about yuck factor or any of the disposal issues which to me are moot if done responsibly. We decided to hold off until we had access to the boat in the spring to confirm it would fit with access to everything necessary. Glad we did as either of the units would have fit perfectly. Our problem was there was no good, visually or structurally acceptable way to route the exhaust hose given the construction of our boat.
So now I'm taking a hard look at the self contained gravity flow unit by Sealand (Dometic) pictured previously in this thread. I'm going to start a new thread for specific input on that unit/concept so as not to get this one way off track.
Mobnets
1973 Paceship Chance 32/28 "Westwind"
Mobnets is offline
post #299 of 443 Old 01-08-2012
Closet Powerboater
MedSailor's Avatar
Mobnets
What I plan to do is plumb the nature's head vent hose out of the side of the hull in an above the waterline through-hull. I've got one there that I'm not using anyway and I'd rather keep my solar vent free for circulating air through the shower and head.
Did you consider going through the hull above the waterline?
MedSailor
post #300 of 443 Old 01-08-2012
Mobnets's Avatar
MedSailor;
No I didn't. Interesting idea but how are you going to prevent water entering when heeled over to that side?
Mobnets
Mobnets is offline
Airhead stevekailua Gear & Maintenance 2 10-27-2006 06:57 PM
Quintess Yacht Tragedy - "The Essence" Sinks In Fatal Collision - Helium Report NewsReader News Feeds 0 09-26-2006 01:20 AM
The Foolproof Head James Baldwin Gear and Maintenance Articles 0 10-25-2004 08:00 PM
Airhead composting toilet rwh Living Aboard 1 08-22-2003 06:57 AM
Airhead composting toilet rwh General Discussion (sailing related) 2 04-08-2003 03:55 AM
