composting toilet report - Page 43 - SailNet Community
 45Likes
post #421 of 443 Old 07-20-2012
Re: composting toilet report
Originally Posted by smurphny View Post
I'm guessing that on the occasional visits by the opposite sex, they will never reach in and touch a lid with (SURPRISE!) poop underneath, moss or no moss. A lid does make a lot of sense because it is probably better at sealing out critters. I can see where there might be a "caking" problem if any part of the stirrer is directly in the line of fire. In the commercial units, the stir mechanism looks like it swings out of the way, shaped like a C. I guess the idea is to just aerate a bit, not try to macerate it.
One can make a simple stainless hook with a handle on it, for lifting the lid out, set near the head..
Brent Swain is offline
post #422 of 443 Old 07-20-2012
Just wanted to say that I just put a C-head in my new (to me) 36' sloop.
It's awesome! On a three week trip from Virginia to Ma. it worked perfectly. Yes it does have an "earthy" smell from the peat moss but that's it. Beats that old nasty head smell and no more having to deal with holding tanks/hoses/pump out boats etc. So easy to use even a cave man could do it.
Brian
Brent Swain and boatsail1 like this.
DoubleEnder is offline
post #423 of 443 Old 07-20-2012
Over Hill Sailing Club
smurphny's Avatar
There is just a little bit of coir in the bucket. When the loop is down it does get covered, out of the firing line. It seems that if the loop is left down and turned slowly 4 times clockwise, 4 counterclockwise, it gives plenty of stir to do a good mix/aeration. The normal level of peat/coir will be higher. The handle is rugged. made the axle from an old pc. of 1" shaft, 3/8" hole drilled through with two 5'16" set screws on a flat ground in the shaft. The spokes are just 5/16" bolts. There's a piece of screen inside the vent tube so critters can't get in that way. I do have the lid with a screw in the top to grab hold of but it will not snap on with the trough in the way. Will try this bucket arrangement but there is room to build in a much larger fiberglass base up along the curvature of the hull. The whole frame could easily be hinged to lift up for access. The bucket should be kinda handy though if it works well enough because when full, the cap can just be snapped on, vent hole plugged, and a new bucket cycled in.
Brent Swain likes this.
smurphny is offline
post #424 of 443 Old 07-23-2012
Boatsail
smurphny, how is the CT working? Like the creativeness
boatsail1 is offline
post #425 of 443 Old 07-24-2012
smurphny's Avatar
Boat is on the hard now so have not put into action yet. This fall will post on how it works out.
smurphny is offline
post #426 of 443 Old 08-12-2012
smurphny's Avatar
Just tested a little 1.8w, $25 solar panel with the computer fan. It seems to work great. Am going to connect this to a small 12v wet cell battery to keep the head vent completely separate from the house battery bank. This way I will have 0 additional amperage draw due to this project.
smurphny is offline
post #427 of 443 Old 04-06-2013
We installed a C-Head in our homemade boat last year, despite feminine misgivings as to esthetics, technique learning curve, and waste-handling workload, but we barged ahead, because dealing with holding tanks, pumputs, stuck valves, permeated hoses, pumpout logs and discharge locks seemed far worse.
Long story short, we are delighted.
-There is NO odor.
-We have had no fly infestations so far, only place in this swamp with no bugs is our head.
-Cleaning and maintenance is very quick and easy. Transferring solid waste is quick and easy. No disassembly necessary.
- The five-gallon secondary solid waste bin holds a lot more than a holding tank would have, months worth at our current rate of usage, and if it fills, we have a spare 5-gallon bucket-and-snap-on lid here somewhere. Try THAT with a full holding tank, miles from the nearest working pump out station.
-Parts for this brand are, for the most part, available at our small-town hardware store. We changed our minds about the toilet seat, and replaced ours for <$15.
-The cabinet is compact, with a narrow footprint, sits flush against the bulkhead, and is no taller than a household toilet. The churn crank needs no space to the side. Very efficient use of space, and comfortable to sit on.
-Need another urine container? At least for this brand, here's another empty water/milk jug. Easy! Cheap! Readily to hand. Unobtrusive to empty, light-weight. No worries about middle-of-the-night overfill. Capping the jug, tucking it in a totebag, and pouring it in the next marina toilet is easy, neat, and at least as environmentally sound as any alternative. For that matter, urine is sterile. If some should accidentally be spilled overboard in open water, I wouldn't be horrified. Not that I would do such an illegal thing.
-Our male guests, so far, seem cool with the "EVERYbody sits to pee" rule. Anybody who finds that requirement an affront to his masculine identity can (perfectly legally) head for the lee rail.
So, it is not a flush-and-forget-it solution like our home toilet, but no boat head is. This, so far, seems like a very reasonable solution to what appears to be a vexing problem to most boaters.
amelia is offline
post #428 of 443 Old 04-06-2013
fryewe's Avatar
Two weeks ago I installed the C-head in a boat I am restoring on the hard. I have been using it and am really pleased with it. Installation is simple... I just put it on the flat surface in the head and lashed it in place. I am not going to vent it unless there is a bit of smell.
I charged it with peat moss and a cup of diatomaceous earth I bought at WalMart. Diatomaceous earth will kill any insect larvae.
But to be honest I'm not sure insects would even find it. The head (the room and not the device ) has that post-go fragrance for a few minutes after use but it goes away just a few minutes after stirring. Pee container can't be smelled either.
I haven't emptied it since I commissioned it. I will keep using it until it is full to see if there is any smell at any point in the fill cycle.
Thanks for the testimonials of the users here. Your experiences convinced me that the C-head was the way to go. Amazingly simple...no salt water supply/no toilet discharge line to holding tank/no holding tank/no holding tank discharge line/no macerator pump/no three way valve/no in-port and at sea discharge penetrations and valves (one above and one below the water line)/no spare parts bin for toilet and valves/no valve maintenance/no troubleshooting when things don't go right/no searching for pump out facility/no $$$ for pump outs/no violating the law when no pump out can be found. And no smell (although to be honest my boat has never had a head smell).
Eliminating all that peripheral plumbing equipment makes a lot of space available for stowage on my small boat.
fryewe is offline
post #429 of 443 Old 04-07-2013
Closet Powerboater
MedSailor's Avatar
You're right! What a great idea! I've been using premethrin insect spray (which works) thinking that since they soak infant malaria nets in the stuff that it should be nice and non-toxic. Well it turn out that its REALLY toxic to cats. Since I have a ship's cat, I need an alternative. Besides it smells. I've heard of using diatomaveous earth in gardening and other applications but for the composting head this sounds like pure genius!
Diatomaceous earth plus coconut coir is hopefully the perfect recipe.
Medsailor
MedSailor is offline
post #430 of 443 Old 04-07-2013
fryewe's Avatar
Medsailor...I can't take credit for that. Sandy of C-heads recommends using diatomaceous earth in his video describing his products and how to use them. I thought it was genius too.
fryewe is offline
Airhead stevekailua Gear & Maintenance 2 10-27-2006 07:57 PM
Quintess Yacht Tragedy - &quot;The Essence&quot; Sinks In Fatal Collision - Helium Report NewsReader News Feeds 0 09-26-2006 02:20 AM
The Foolproof Head James Baldwin Gear and Maintenance Articles 0 10-25-2004 09:00 PM
Airhead composting toilet rwh Living Aboard 1 08-22-2003 07:57 AM
Airhead composting toilet rwh General Discussion (sailing related) 2 04-08-2003 04:55 AM
