composting toilet report - Page 44 - SailNet Community
 45Likes
post #431 of 443 Old 04-13-2013
troy2000's Avatar
Re: composting toilet report
I've had a C-head in my motor home for a few months now, as a test run for installing it in the boat I'm building.
My only question at this point is, "do I yank my motor home's C-Head for the boat, and reinstall the water-flushing toilet it replaced -- or leave it there, bite the bullet and buy another one for the boat?
The answer should be pretty simple. But I'm a cheapskate, and 500 bucks is 500 bucks.....
troy2000 is offline
post #432 of 443 Old 04-15-2013
Is anyone familiar with the 'incinerating toilets' used on inland Tugs?
Cost?
Use too much electricity?
hughdon is offline
post #433 of 443 Old 04-15-2013
That's an "Incinolet".
Be still my heart.
Aside from needing, yes, a freaking lot of power for the long burn cycle, and the somewhat delicate concern of "I'm about to place my bare ass IN a furnace and hang out for a while..."
Oh, and you drop in a paper liner something like a coffee filter before each use/cycle.
Around two grand and needing 2000 watts for 45? minutes. If you can afford 2kwh out of your power every time you flush, no pun intended, wouldn't that be a nice way to go?
hellosailor is offline
post #434 of 443 Old 04-15-2013
Aspiring to be a Mexican
sww914's Avatar
We bought a C-Head after a couple of poo showers due to a clogging vent. I guess you could say that we'd had enough of that sh!t.
My wife wrote up the whole deal on our blog if you want to read it. I still can't believe that C-Head linked to it as a review.
It's here- Day 10: The **** Diaries, Golden Showers and **** Landfall Voyages
sww914 is offline
post #435 of 443 Old 04-16-2013
troy2000's Avatar
Tks for the link. It's a good write-up, and it agrees with my personal experience using the C-Head.
The biggest knock I've had on mine is people carrying on about the fact that it has to be emptied more often than the Nature's Head or Air Head. But c'mon, folks.... emptying a C-Head is about as hard as taking out the kitchen trash. Even easier actually, because you don't have to stick a new bag in it afterwards.
troy2000 is offline
post #436 of 443 Old 04-18-2013
The Humanure Handbook is still available for download by chapters in pdf format:
Look for table of contents.
One thing that hasn't been touched on in this discussion is aerobic purification and decomposition of human waste, such as is used in municipal treatment plants where treatment has to proceed at a brisk pace through the use of sprayers or waterfalls. Composting tends to depend on this similar process to kill pathogens without the liquid environment through the use of dry bulking agents to maintain oxygen levels. One of the advantages of the C-head is the storage of batches for further decomposition without the addition of fresh material. Unfortunately, the exclusion of air by sealing the container stops the aerobic purification process just as not turning a compost pile slows the decomposition and purification process. In a larger composting system the compost is withdrawn from the bottom of the chamber, where the decomposition process has been completed. However since it is an actively used system, there is still potential for contamination; thus the warnings and concerns about handling composted human waste. There is a report put out by the EPA that charts the life of the various pathogens found in human waste products when exposed to various environments.
Search this since I can't post links:
water.epa.gov/aboutow/owm/upload/2005_07_14_comp.pdf
Also, very little is said about municipal treatment plants that empty their effluent into our waterways and oceans, especially when these systems are overloaded by storm sewer runoff. Contrary to common beliefs, most cities (especially large older coastal cities) still have not completed the federally mandated process of separating storm water from sewage lines. So when you take your boat to the pumpout station today, it doesn't mean your waste is being handled properly. What it means is that you will likely be drinking it tomorrow!
highwind is offline
post #437 of 443 Old 04-18-2013
I should add that sunlight is also a great purifier, as well. So when you dump your compost out of your bucket you could be doing our environment a favor.
highwind is offline
post #438 of 443 Old 04-18-2013
For those people with troubled holding tank systems, the addition of air into the holding tank has been recommended to reduce odors. Most recommendations center around larger and shorter ventilation hoses.
highwind is offline
post #439 of 443 Old 04-18-2013
sww914's Avatar
Since I can't post links you have to add http, etc. at the beginning to complete the preceding url.
My C-Head came with a venting system for the secondary storage container.
sww914 is offline
post #440 of 443 Old 04-18-2013
Sorry. You're right. There is the vent system that comes with the system. I just remembered the comments about storing the full container with a sealed lid...
highwind is offline
Airhead stevekailua Gear & Maintenance 2 10-27-2006 06:57 PM
Quintess Yacht Tragedy - "The Essence" Sinks In Fatal Collision - Helium Report NewsReader News Feeds 0 09-26-2006 01:20 AM
The Foolproof Head James Baldwin Gear and Maintenance Articles 0 10-25-2004 08:00 PM
Airhead composting toilet rwh Living Aboard 1 08-22-2003 06:57 AM
Airhead composting toilet rwh General Discussion (sailing related) 2 04-08-2003 03:55 AM
