10-04-2009
Whale Gusher of guzzler?
If it's the Whale Gusher, it's a great pump and having it installed in the cockpit is correct. scottyt is correct in that the flappers can become clogged and/or brittle enough that they don't seat right. The aluminum housing can also become corroded and cause problems sucking. I bought a rebuild kit, scrapped out all the old crud and the pump works great. Figure on a rebuild every 5 years or so. Maybe longer or shorter depending on use, water type, etc.
Sabre 38 "Victoria"
