10-05-2009
Looks like a lot of the equipment here would be used for my A/C (intake thru-hulls, strainer, impeller based feed water pump, output thru-hull above the waterline, etc). What are opinions around t-ing into that existing equipment for this watermaker?
Another benefit for me is that my water tanks are already on the port side, right by where the A/C intake already is, so piping runs will be smaller to boot.
Although there would be a looong way to pipe for an engine mounted pump. May have to go 120V pump for the high pressure side of things.
S/V Jendai
Beneteau 343
