10-06-2009
Chesapeake Sailor
Chip,
I have a Frigiboat system as well. If the system is the same as mine, it uses seawater to cool the refrigerant. The seawater cooling coil contains a sacrificial zinc anode. The installer may need to know if you use a whole boat thru-hull electrical bond. My boat does not and I agree with Brian. If yours is bonded, the installer would connect it (electrically) to the others.
Wayne
