Bending a bow pulpit to fit - Page 2 - SailNet Community
post #11 of 15 Old 10-22-2009 Thread Starter
Originally Posted by scottyt View Post
i have tried to get mine to straighten to where i need it and it wont move. i have to make a new one in the spring, or use hydrolics to try to bend it
Hey Scottyt,
Have you tried the conduit bender yet? I've got one for sale, cheap. I tried to bend it with out tying it down and got nowhere. After I secured the area next to where I wanted the bend to occur, so it would not move, I was able to apply bends pretty precisely to the location I wanted to. My first bend was too much and I had to remove some of it. I then put a few bends on each side I wanted to bow out so it came out as a smooth curve along the section instead of a single bend.
Granted mine is pretty basic and the amount of movement I had to make was simple, but you might get something more square then let the bolts do the rest.
Jordan
West Wight Potter 14 "Lemon Drop"
Oceanside CA
Last edited by jephotog; 10-22-2009 at 04:34 PM. Reason: advertise my conduit bender for sale
jephotog is offline
post #12 of 15 Old 10-22-2009
i wish my pulpit was that easy to bend. mine has a top and a lower pipe plus 4 verticals ones and its racked out of square. i have tried to get mine to straighten to where i need it and it wont move. i have to make a new one in the spring, or use hydrolics to try to bend it
Having been an electrician in a former career I learned how to fix my mistakes! The tough part is always holding the darn thing. You might try to find a welding shop with a welding platten with the square holes. These things are a big thick steel table abut 2" thick. The square holes hold all kinds of clamps. This allows you to clamp something down really solid, and gives you a place to push or pull from.
Gary H. Lucas
GaryHLucas is offline
post #13 of 15 Old 10-22-2009
jordan and gary, i am amaster electrician, i already have the benders. i have tried it the problem is its its racked. and out of square. it needs a jack to un rack it
scottyt is offline
post #14 of 15 Old 10-22-2009
That is the tough case, which why I suggested the welding bench approach. If you can hold it down you might not even need the bender.
Gary H. Lucas
post #15 of 15 Old 10-23-2009
I have had good luck and great results straightening pulpits and rails out using come-alongs, chains/straps and wood. If you could provide pics of what it's like I could maybe throw a few ideas out.
Ken.
merc2dogs is offline
Disposing of Bow Pulpit ? domingodp General Discussion (sailing related) 13 10-02-2006 12:53 AM
Bow Pulpit for Catalina 38 sailnaway Gear & Maintenance 9 12-04-2004 08:45 PM
Bases for bow pulpit LuckyinLA Gear & Maintenance 4 09-28-2003 10:12 AM
Choosing and Installing an Electric Windlass Sue & Larry Gear and Maintenance Articles 0 09-06-2002 09:00 PM
The Basics of Doing the Bow Rich Bowen Racing Articles 0 03-20-2002 08:00 PM
