Old 10-07-2009
HARDWORK is on a distinguished road
Which gen-set do you have?
I am in need of a gen-set. I have an Endeavour 33 that has enough room for a small footprint unit. Currently I am using a Honda EU2000 that I carry on deck for my trips. It works great for my purposes, but I am looking for a more permanent solution. I would like to have at least 3kw to run the air conditioner if possible.Thanks for your suggestions.
Old 10-07-2009
CaptainForce's Avatar
I'm very pleased with my Next Generation diesel genset that's built with a 12hp Kubota....very low maintenance and reliable. 'take care and joy, Aythya crew
Old 10-08-2009
negrini is on a distinguished road
Send a message via AIM to negrini Send a message via Yahoo to negrini Send a message via Skype™ to negrini
I had MasterVolt 3.5, although reliable and easy on maintenance, it was very bad on noise and vibration. Wouldn't have one again. My actual EU2000 is enough to run our 12.000BTU Vector alone, and it's perfect for charging batts, microwave, etc ... but I'm also looking for a permanent mount. My pick will be the Onan 5KVA. I had the opportunity to look at several instalations on 40+ feets boats and its very low noise and vibration (runs at 2900 rpm).
Nave Rara
Beneteau Oceanis 43
Old 10-08-2009
AirbusDriver's Avatar
AirbusDriver is on a distinguished road
My previous boat (Catalina 30) had a aftermarket 4KW diesel generator(German brand??) in the cockpit lazrette. It was extremely noisy, even with the soundproofing material. Plus the maintence of a impeller, fuel filter...is was a major PITA. On my new to me boat (Endeavourcat 30) I bought a Honda EU2000I and am so pleased with it. I just put the genny on the forward deck and can barely hear it hum while we are in the cockpit. It charges my batteries and runs our hatch air conditioner. My endeavourcat 30 is also has a gas outboard so only one type of jerry can to bring. I am sure this will be a disadvantage to all who have an inboard diesel. I would stick with the Honda.
EndeavourCat 30
St. Petersburg, FL
Costal Cursier Wannabe
Old 10-09-2009
HerbDB's Avatar
HerbDB is on a distinguished road
We have a Westerbeke 4.3Kw genset installed in our engine room which is located under the cockpit (center cockpit boat). It handles all of the charging and will run the AC and heat.
Due to the central location, we found it noisy inside the cabin. Outside, the only noticeable noise is the water splashing out of the exhaust.
I think Westerbeke makes a 3.8 Kw now, it looks the same as mine.
We used it almost daily during a six month trip to the Bahamas. We have a fairly high electrical requirement on our boat and found that running it two hours a day was required to maintain the batteries if we were not moving the boat and charging with the engine. We usually ran it an hour in the morning and and hour in the evening.
This allowed the use of the AC when we were cooking if the cabin was heating up. Plus we could use the microwave or convection oven without draining the batteries too much. The inverters took care of other AC electrical requirements.
The genset made our Bahamas trip more comfortable and when cruising locally allowed us to comfortably extend our season. I think it is a good idea to have one installed if you have the room.
Be sure to install and maintain a Carbon Monoxide detector. It is possible in situations where a strong current opposes the wind to get exhaust gas in the air intakes of the AC or into the cabin if you have the hatches and ports open.
Herb DuBois
Beneteau 36CC
Split Decision
Old 10-27-2009
bshipp's Avatar
bshipp is on a distinguished road
Wow. Great feedback here. I also have an EU2000, which meets my immediate needs but does not make me the most popular guy in the raft at 8am when I start her up. I was also hoping for something to use while underway. I have rather limited space (what sailor doesn't), so the Panda looked very appealing. However, I've read some horror stories about Panda after-sale support, service and reliability. I have a Westerbeke engine which has been solid (with a few replacements, of course) and is easy to get serviced. The Westerbeke enclosure looks pretty large, though. The Next-Gen looks rather appealing. A kubota engine is about as standard as you can get. However, the Westerbeke runs at about 1800rpm vs 2600 or so for the Next-Gen. I like the idea of a lower RPM engine.
I'm thinking of either a 3.5kw or a 5kw AC genset. I really only need to run a shore battery charger and an AC hot water heater, so 3kw would work, but I like to over-engineer.
Any thoughts?
Brad
"England expects that every man will do his duty."
Old 10-27-2009
Zanshin's Avatar
Zanshin is on a distinguished road
I'm on my second Fischer Panda and am still happy. The current one (a Fischer Panda 5000) is underneath the floorboards with the standard enclosure, then I surrounded it on 5 sides with Whispermat and now I can barely tell that the genset is running when in main cabin, up top I can't hear or feel a thing.
Old 10-27-2009
speciald's Avatar
Special Delivery
speciald is on a distinguished road
Send a message via Skype™ to speciald
Stay away from the high reving sets like Fisher-Panda and Mastervolt. Diesel motors don't like to run at very high speeds for long periods. F-P has had cooling problems and they have redesigned their systems in the last few years - I don't have any experience with the new design but the two F-P's I have had have been thrown away after blown head gaskets, warped heads, and many $ in repairs. I now have a Northern lights that is just as quiet but 5-6 times the size of the F-P.
Old 10-28-2009
bshipp's Avatar
The Westerbeke units run at about 1800 rpm, which makes it appealing for just that reason. Their 4kw unit is just a lot bigger and heavier. Like most sailors I have pretty limited space. But of course the fact that it IS bigger and heavier probably lends to its reliability.
I'm also mostly a weekend cruiser, not a trans-atlantic sailor. The generator isn't going to get all that much use. If I put 100 hours on it a year I'd be surprised.
I have heard horror stories about FP reliability and also their customer service, but the unit looks really appealing otherwise.
Brad
Old 10-28-2009
christyleigh's Avatar
christyleigh is on a distinguished road
That's why when my 10 year old FP gives up the ghost I'll probably replace it with the exact same thing..... or as has been said... the "newer improved model".
Stan
'Christy Leigh'
NC 331
Wickford/Narragansett Bay RI
The Salt's Corner Table smackdaddy General Discussion (sailing related) 125 10-02-2011 06:10 PM
Using the Asymmetrical Spinnaker Brian Hancock Gear and Maintenance Articles 0 08-30-2004 08:00 PM
Refining Your Downwind Sails Brian Hancock Gear and Maintenance Articles 0 04-06-2004 08:00 PM
Bear-Away Spinnaker Sets Dean Brenner Racing Articles 0 01-30-2002 07:00 PM
Set and Drift Made Simple Jim Sexton Seamanship Articles 0 04-19-2000 08:00 PM
