10-08-2009
ASA and PSIA Instructor
It is pretty common for water to collect in a hull/keel joint, and to weep out for a week or two after hauling. Most likely any apparent weeping in the spring is rain water, either collecting at the top of the keel, then weeping, or just re-wetting the old stain. If the water were coming from the bilge, you would see sea water collecting in the bilge while afloat.
Clean the area and epoxy, use a layer of glass if you have to do it more than one season.
