12-12-2009
I always put the cutlass bearing in a stainless steel bowl of salt water, then in the freezer over night. Freezing the bearing in dry ice would also work, but I have found frozen bearing in the bottom of a deep freeze in salt water works every time so far. Have your threaded rod, and helper to hold wrench inside boat, work fast, and draw the new bearing into it's race.
Why, why, why? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
