Old 10-10-2009
.....and a bottle of rum
yohoho is on a distinguished road
Operating temp for Perkins 4-108 ????
My workshop manual for my Perkins 4-108 is amazingly detailed in every respect except a few crucial areas, namely -
What is the operating temp range of this engine ?
What revs should it be pulling when operating at it's most economical ?
Anyone ???
Old 10-10-2009
btrayfors will become famous soon enough btrayfors will become famous soon enough
Temp: 180-190F
RPMs: depends on setup aboard your boat. About 2200-2300 RPM is right for mine (42' 27.5K lb displacement hull, 3-blade 17" Max Prop).
Bill
Old 10-10-2009
lancelot9898 is on a distinguished road
Temperature around 180
I cruise at 1900 rpm around 6 knots with a 17 inch Max prop set at 14 inch pitch. 37 ft. Tayana 30000lbs displacement
FWIW....the engine is rated at 4000rpm max rating with continuous rating of 3600 built in 1985
WOT is 2300 with my current prop
Old 10-10-2009
Lancelot,
30K displacement? For a Tayana 37? Normally they weigh in at 22,500lbs. What are you carrying?
Also, if you can only get 2300rpm with a wide open throttle, you're very likely to be overpropped (or over-pitched). Unless there's something seriously wrong with your 4-108.
IMHO
Bill
Old 10-10-2009
Originally Posted by btrayfors View Post
Lancelot,
IMHO
Bill
The design weight is 22.5 K but on the travel lift it registered at a little over 30K. Not sure how well calibrated those strain gages were, but I bet it's closer to 30 than 22.
For years my engine tach has been reading on the high side with me not knowing it until I put a photo tach on it just last month. I had adjusted the max prop years before to give me 3000 rpm at WOT on my engine tach reading, but that reading is really 2300rpm. I think that as long as I'm running the engine under load and achieving rated temperatures that no harm is done. The only penality I see is that the developed hp is less at lower rpm's. Under no load that engine will read 4000 on the engine tach. (probably around 3000rpm but did not photo tach that reading since very high revs)
Another observation is when tied at dock and in gear WOT is 2150 while underway the WOT is 2300. Based on this I would assume that if running against a current that WOT would even be higher?? Usually I'm in a narrow channel and contending with a draw bridge when contrary currents are encountered, but one of these days I'll crank it up to see is the theory holds.
Old 10-10-2009
Yeah, lots of things can affect "registered" and actual rpm: dirty bottom, dirty prop, too much pitch or too big a prop, impaired engine (multiple reasons), etc.
BTW, travel lift guages are notoriously unreliable. Unless you've shipped a hell of a lot of stuff, I'd bet on the 22.5K plus gear.
So, too, are tach readings. But, if you've got the right prop for your boat, you should be seeing a lot more than 2200-2300 rpm for the 4-108 as a maximum.
Bill
Old 10-11-2009
poopdeckpappy's Avatar
poopdeckpappy has a spectacular aura about poopdeckpappy has a spectacular aura about
My Perk 4-108 runs around 190 degs
1978 Tayana 37
Freedom comes when you’re ready to sail away. True freedom comes when you don’t have to return
Cut off from the land that bore us, betrayed by the land we find, where the brightest have gone before us and the dullest remain behind, .......but stand to your glasses, steady,.......tis all we have left to prize, raise a cup to the dead already, hurrah for the next that dies
First Challenge and Success-- Temp Sender Jim H Atomic 4 0 04-10-2006 09:04 PM
Water temp sensors, gauges elhanley General Discussion (sailing related) 2 12-10-2004 02:30 PM
