Rebedding aluminum toe rails - Page 2 - SailNet Community
post #11 of 14 Old 10-15-2009 Thread Starter
Beneteau F310 ~ APOTHIC
cghubbell's Avatar
Dock
I'd point out that Butyl tape has the advantage of a very long working time....unlike some of the other sealants you might use, which start to cure rather quickly.
I definitely had concerns about working time. I can only imagine how likely it is that I'll get tangled up somewhere along the hundreds of bolts on this thing.
Ok. Butyl it is. Now to find a day when the temperature is favorable for working with this stuff!
Beneteau F310 ~ Apothic
PYC, Lake Ontario
cghubbell is offline
post #12 of 14 Old 10-15-2009
tommays's Avatar
One lesson i learned on a friends 35' was to NOT turn the screws BUT have someone below with the correct wrench turning the NUTS were ever possible while someone on deck held the screwdriver
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #13 of 14 Old 10-15-2009
mitiempo's Avatar
I agree with tommays. It's a 2 person job however you look at it. Good luck.
Brian
mitiempo is offline
post #14 of 14 Old 10-15-2009
Custom Member
Stiche's Avatar
Originally Posted by mitiempo View Post
The bolts should be tightened when the caulking is put on, not later otherwise you run the risk of breaking the seal you're trying to create if a bolt turns on set caulking. Don't listen to Casey on this - he's wrong.
Brian
I love a good discussion on adhesives Always entertaining
Stiche is offline
cleaning aluminum water tank rbtpfe9 Gear & Maintenance 18 12-27-2010 11:31 AM
non teak rub rails and toe boards? jbarros Gear & Maintenance 3 11-04-2003 08:51 PM
