10-14-2009
The problem is the piss-poor engineering of the hatch slider in the first place. By using the black metal strips to hold the acrylic down, they've effectively trapped the water on top of the acrylic slider, forcing the water to flow under the strips and into the gutter.
What they should have done is attached the slider from the underside, and had it extend slightly outboard of the white "slider rails", so that the majority of the water would end up pouring down the cabintop, as seen in this image:
This would probably be fairly easy to retrofit to fit under your existing seahood.
