Holding Tank Odor - Page 2 - SailNet Community
post #11 of 16 Old 10-15-2009
IF you want to test the hoses, pour really hot water over a cotton cloth, and place the cloth against the hose....wait a few minutes and then take the cloth and see if it stinks... if it does, the hose is permeated and needs replacement.
Vinegar is a good deodorizer.
óCpt. Mal Reynolds, Serenity (edited)
StillóDON'T READ THAT POST AGAIN.
sailingdog is offline
post #12 of 16 Old 10-15-2009
I agree with others. Replace the plumbing. Saltwater critters grow in the plumbing. In the future frequently flush fresh water through and it should keep the funk at bay.
MichaelNW
Michael Paulson
Brinestormer
Mercator Offshore 30
MichaelNW is offline
post #13 of 16 Old 10-16-2009
mitiempo's Avatar
I agree with the others - it's most probably the hoses. If after replacing all hoses there is still a problem, which is unlikely, replace the tank with plastic - thick walled. Stainless steel is not a good material for a holding tank nor is aluminum - nothing can corrode metal like what's in a holding tank. Why should you replace the tank if it comes to that with another plastic one? The one there is probably quite old and if it's the tank it won't happen to a new tank for a long, long time.
Brian
mitiempo is offline
post #14 of 16 Old 10-16-2009 Thread Starter
Thanks everyone.
I can't wait to be able to sleep without holding my breath all night.
BudRICKETT is offline
post #15 of 16 Old 10-16-2009
Coastal Traveler
nereussailor's Avatar
Send a message via Yahoo to nereussailor
I second what sailngdog said, and you can do the same with the tank.
I cleaned my tank good and the smell went away. There is still some coming from the head itself, but a rebuild is in the works for Monday. It's going to be much cooler then.
Dave
nereussailor is offline
post #16 of 16 Old 10-16-2009
Arf!
pegasus1457's Avatar
Dollars to donuts it's not the tank
Originally Posted by BudRICKETT View Post
Sorry, the boat is a 1979 Pearson 32.
I would have to cut it out.
Since this plastic tank stinks, why wouldn't a new plastic tank stink?
I diligently searched for a leak. Didn't check the vent pipe though.
I have a P32 vintage 1980 which stank to high heaven inside when I took ownership 2 years ago. The smell was so bad I could taste it in my mouth after leaving the boat.
I also have a plastic tank under the V berth, which I did not replace.
I replaced all of the waste plumbing (the 1-1/2 inch stuff) with odorfree tubing. This stuff is expensive ($9/ft or somewhat less if you buy a 50' reel) but when I was done there was no detectable odor.
I would bet that your tank is not the culprit.
Fluctuat nec mergitur
pegasus1457 is offline
Flexible holding tank installation sarafinadh Gear & Maintenance 29 10-17-2009 07:46 PM
Diesel And Holding Tank Odor pandaman Gear & Maintenance 0 02-23-2006 03:47 PM
Odor Control Kathy Barron Gear and Maintenance Articles 0 09-02-2003 08:00 PM
Odor Control Kathy Barron Her Sailnet Articles 0 09-02-2003 08:00 PM
Holding Tanks Tom Wood Gear and Maintenance Articles 0 06-10-1999 08:00 PM
