10-15-2009
A raycor-type fuel water seporator would give you a good look at what your getting..
Originally Posted by n0w0rries
Does anybody have any experience with removing the 17 gal fuel tank from a 1980 Catalina 27? I'm not sure if I'm getting water in my tank, or if it's dying from the inside out and needs to be replaced. Going to go mess with it tomorrow. Don't want to blow myself up. I didn't see any vent on the side of the hull, so I guess I'll find out where it goes tomorrow. Also going to cut some of filters in half to see what kinda stuff is in them.
Can you get the tank out through the hatch without cutting it (the hatch or the tank)? It looks like it might fit thru. Not looking forward to working on this! But having an unreliable iron genny is a drag!
..might solve your problem, and would be a good investment in reliability, gas or diesel. The smallest size with a drain and clear bowl is what you need.
(when asked how he reached the starting holds on a difficult rock climbing problem that clearly favored taller climbers - he was perhaps 5'5")
"Well, I just climb up to them."
by Joe Brown, English rock climber
