10-16-2009
Hard to tell after such a brief description.
You should, first of all, check if the water is fresh or salty. (I presume it to be fresh because you mentioned your pillows were wet)
If it is fresh, obviously, it came from "above" and the best way to check how it is sneaking in is to either spend some time in the cabin while rainig hard or ask someone to pour some water over the cabin with a hose (or a bucket) while you are inside and searching for leaks (this has the advantage of having your boat washed by someone else while you're sitting comfortably inside  ). Check arround hatches, rig fittings, portholes, siderail bases, etc...
Once I had a problem just like yours that was tricky to find. In fact I only found it when by coincidence I had to bring my mast down. The problem was a cracked stainless steel mast base that was allowing water in by the bolt holes...
Good luck!
Pedro
Portugal
