Old 10-20-2009
GaiaOrion is on a distinguished road
Diesel foot massage
Hey,
are single lung dieasels (yanmar 12 HP) supposed to shake the cockpit like an earthquake upon start up? She idled smoother, but should I check the mounts? As well, can you do a compresion test on on of these- where do you screw in the tester ?
On a seperate note, what does " varied moisture readings in the deck and cockpit sole, with no evidence of delamination - used brass hammer " mean?
Thanks for the insights.
Old 10-20-2009
deniseO30's Avatar
Lies about her age
I think only 3 or more cylinders will run smooth. I've a 2 banger and it shakes at certain rpms.
survey says! you have moisture in your decks but, they are not delaminating yet. The brass hammmer gives a dull sound when the damp core is evident. a crisp rap or chirp means it's still solid.
Old 10-20-2009
mitiempo's Avatar
Hi
Most one lunger diesels will shake a bit at certain rpm settings. Best to either speed up or slow down until it smoothes out a bit.
As far as the moisture readings Denise is right, but your surveyor should have explained this to you. Unless it's an old survey as opposed to one you commisioned yourself. Things can change over time so an old survey is really only a guide and you should get your own if looking to purchase. Is it an Ontario 28?
Hope this helps.
Brian
Old 10-20-2009
erps's Avatar
the pointy end is the bow
We looked at a Cal 26? or 27?, I forget which, that had a single cylinder Ferryman (sp?) diesel in it. We really liked the boat until he started it up. The vibration was so bad at idle that it was a deal breaker for us.
Ray
S.V. Nikko
1983 Fraser 41
La Conner, WA
Old 10-20-2009
mitiempo's Avatar
My current boat, a CS27 has a Yanmar YSE8 single cylinder 8hp and vibrates at some rpms which I avoid. In 1972 I had a Westerly 25 twin keel boat with a Volvo MD1. At idle the entire rig shook in that boat until the throttle was increased.
Brian
Old 10-21-2009
WanderingStar is on a distinguished road
That Yanmar is a great engine, but it does shake. I would look at the mounts and the bed to reassure myself.
Old 10-21-2009
Originally Posted by GaiaOrion View Post
....As well, can you do a compresion test on on of these- where do you screw in the tester ?.
You remove the injector and use the tester as you would with a gas engine and it's spark plug.
Sounds like you're reading an old survey... depending on how old it is you may want to consider another.
1984 Fast/Nicholson 345
Converting water tank to diesel tank - fittings? Zanshin Gear & Maintenance 5 09-15-2009 05:38 AM
Diesel Fuel Essentials Tom Wood Gear and Maintenance Articles 0 03-22-2004 07:00 PM
Diesel Fuel Essentials Tom Wood Her Sailnet Articles 0 03-22-2004 07:00 PM
Gas versus Diesel Tom Wood Gear and Maintenance Articles 0 01-10-2002 07:00 PM
The Diesel Generator Mark Matthews Gear and Maintenance Articles 0 03-25-2001 07:00 PM
