Old 10-22-2009
ajohns is on a distinguished road
Awlgrip -vs- interlux brightsides
I'm in a restoration project and now ready to start painting. Boat is fiberglass and I'm leaning towards Awlgrip but really like the price of Brightsides.
Anyone have experience with either one that can sway me to one side?
Thanks
Old 10-22-2009
tommays's Avatar
Your not doing and apple to apple compare BOTH companies (same ownership) make two part paints that are much tougher and a small part of the job cost
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
Old 10-22-2009
CharlieCobra's Avatar
On the hard
CharlieCobra has a spectacular aura about CharlieCobra has a spectacular aura about
Oh Joy has 15 year old Awlgrip on her. Not a lot of gloss left but no failures either. I used Alumigrip on aircraft with great results when I did that kinda work. Great stuff, very similar formula.
Baggett and Sons Marine Restoration
The Landing at Colony Wharf
Bellingham, WA.
Old 10-22-2009
Maine Sail's Avatar
Lexus vs. Yugo
You do tend to get what you pay for..
______
-Maine Sail / CS-36T
Old 10-22-2009
I'd point out that the majority of the investment in repainting is the labor of prepping the boat...and if you're going to go through all that, going with a one-part like Brightsides is going to cost you a lot more in the long run. A two-part paint, like Awlgrip, is far more durable and going to last longer and the difference in the cost of the paint is a minor thing over the long run.
Old 10-22-2009
mikehoyt's Avatar
mikehoyt is on a distinguished road
A lot also depends on what you are painting.
Brightsides is much easier to apply DIY with brush or roller and has better flow characteristics I believe. For sometihng like the inside of a cabin top is a great paint.
If you are finishing topside of the hull a two part product is much more durable, more difficult to work with and much more expensive. The two part products such as Tommays Interlux Perfection or the Awlgrip you mentions will last much longer in a high traffic compared to a one part product such as brightsides that will likely require repainting in 5 or six years ....
I restored an old Laser. It was rough and we paid little for it. I used Brightsides and the results was spectacular. Next year I am repainting the hull after only 3 seasons - was always the plan. Will use Awlgrip but only because we had a leftover can from another project.
Mike
Mike
Old 10-22-2009
JohnRPollard's Avatar
Moderator
They are very different paints and not really comparable. Awlgrip is a high-end two-part paint that requires extensive prep and skilled application. Brightsides is a single-part paint that is much less expensive, more forgiving, and easily applied by any reasonably competent amateur. I am not even a reasonably competent amateur and I got good results. I wouldn't trust myself with Awlgrip.
If you decide to go with Brightside, I would urge you to consider spending just a bit more and use Toplac instead (also by Interlux). Having used both, I've found Toplac to be a more resilient paint and yields better finish quality.
Old 10-22-2009
Greenflash35's Avatar
Greenflash35 is on a distinguished road
I'd rather paint because I'm doing all the labor. My partner who isn't doing any labor yet paying for it is insisting on Gelcoating the Hull. Can someone explain other than being more durable at the cost of a lot more work for me why Paint is better than Gel Coat? Awlgrip -vs- Interlux -vs- Gelcoat.
Old 10-22-2009
NICHOLSON58's Avatar
Mark on Camper 58
NICHOLSON58 is on a distinguished road
We are in the midst of recovering our hurricane damaged boat. It had road-rash down both sides. I tried to DIY with Perfection above the water line but we dicided to have it done by the yard. I just could not get a satisfactory appearance myself. We saved a pile by doing the repair and prep work ourselves including the masking. Torresens in Muskegon finished it with AWL GRIP - indoor controled paint shed. Fabulous job! The shine is visible for miles. DIY is fine but if you want art work, hire an artist. We did the masts ourselves using Perfection. That is quite satisfactory as DIY. After a few fits & starts we decided forever, only two-part stuff on the exterior. It lasts longer and there is never any failure to adhere due to incompatability.
Old 10-22-2009
jaschrumpf's Avatar
1975 Newport 28
jaschrumpf is on a distinguished road
My boat has a navy blue hull. I have no idea what kind of paint was used, but looking at it you can tell it wasn't a real professional job: wavy finish in places, elsewhere it looks like it was applied with a brush.
My interest is in touching up some dock rash spots. Under the navy paint is a light blue color (primer?), and I'd just like to cover those up. I'm not concerned with making it perfect, just close -- just like covering up some scratches on your car with touchup paint.
Would a one- or two-part paint be the way to go for a job like this? Does the experience necessary for a two-part Awlgrip become less important for touching up scratches, or does it magnify the need? Does the "hold" of a one-part paint become less important as a touchup, or vice-versa?
Update: I didn't see Nicholson58's post before I wrote mine. Of course, my dock rash isn't hurricane-induced, so maybe my situation is different. Just a few small spots here and there.
S/V Free Spirit
Monrovia, MD
Awlgrip care owlmtn Gear & Maintenance 6 04-25-2005 07:17 AM
Interlux Perfection Varnish (2 part) mikehoyt Gear & Maintenance 0 05-31-2004 05:50 AM
1 Party poly over Awlgrip? VIEXILE Gear & Maintenance 3 07-18-2003 09:44 AM
awlgrip ksmo62 General Discussion (sailing related) 5 11-29-2002 04:11 AM
awlgrip ksmo62 Gear & Maintenance 2 11-17-2002 06:43 AM
