Old 12-30-2002
bayme is on a distinguished road
Replacing a headliner
does anyone have any experience replacing a headliner on a sailboat, and what did theyt use
  #2
Old 01-10-2003
flysurfer is on a distinguished road
There are several different types available online from Sailrite. They offer foam backed as well as color options. Their web site is Sailrite.com.
  #3
Old 01-10-2003
peterpan2k is on a distinguished road
That sounds alot like a commercial to me. You could use any color vinyl fabric backed material that you can get at most fabric stores. Car upholestry shops have a good supply too.
Jim
  #4
Old 01-22-2003
gpuerini is on a distinguished road
Theres an interesting article in SAIL magizine this month, on how to replace with wood.
  #5
Old 02-12-2003
petercra is on a distinguished road
I replaced mine with an FRP panel from Home Depot. It worked, but aesthetics leave a bit to be desired. It would have been perfect if I''d found a panel which had a smooth finish. The only panels I could find had a pebble finish on the glossy side and a flat matte finish on the other side. I mounted with the matte finish showing which wasn''t ideal as that side has some imperfections.
Does anyone know of a source of FRP panels with a smooth finish?
The prior headliner was wood with a thin vinyl covering. Water had leaked from a hatch and destroyed a part of it. The FRP panel was slightly thinner but that wasn''t a problem.
Foam backed vinyl wouldn''t have worked on my boat as the headliner is separated from the fiberglass deck by 1/2" plywood strips so that hardware can be bolted through the deck. Without the spacer the bolts would show.
  #6
Old 02-13-2003
jklewissf is on a distinguished road
pulltruded fiberglass panels are available from www.rparts.com. They sell them for use in ice box building and claim that they are smooth enough to be easily cleaned even if you dont paint them. I think the biggest size they offer is 4X4
I wonder if you could just use formica for the panels overhead. Its strong, easily cleaned and can be bent into gentle curves pretty easily.
  #7
Old 02-13-2003
One more thought on replacing the overhead on your boat. Try to get a look at a Tayana boat. They do their overheads with a white plastic material held up by varnished teak battens. It looks nice and makes access behind the panels really easy if you want to pull wires or install deck hardware.
You may post attachments
You may edit your posts
Headliner replacement options? DelmarRey Gear & Maintenance 14 04-23-2011 01:55 PM
Replacing Halyards capttb Gear & Maintenance 11 04-23-2004 09:07 AM
Replacing your old SmartPak??? MDDesperado Gear & Maintenance 0 10-15-2003 06:10 AM
replacing my rubrail Sailmale Gear & Maintenance 0 05-30-2002 11:28 AM
Westerly Centaur Headliner Centaur Gear & Maintenance 3 10-28-2000 08:28 AM
SEO by vBSEO 3.6.1
