10-25-2009
Retired and happy
In addition to all those mentioned so far, I would add leaking portlights. I recently sealed all of ours and it made quite a difference to water ingress. Most of the water in the bilge now comes from the dripping stuffing box. Although it is supposed to drip even when the prop shaft is not turning, it is in need of re-stuffing (if you will pardon the expression) and therefore more incontinent than it should be.
Incidentally, not long after I bought the boat (a Morgan 30), I went down to the dock one day after it been raining heavily for several days. The bilge was full to the brim with water. On investigation, this turned out to be due to two things. Firstly, the cockpit drain was teed into the bilge pump plumbing and the pipe runs were such that the water could drain from the cockpit and down into the bilge  . Secondly, water from the leaking portlights had got in amongst the bilge pump wiring and cunningly disabled the automatic function. Relocating said wiring and re-plumbing the drains and bilge pump sorted that problem. It was a salutary lesson. If I hadn't been in the habit of going down to the dock regularly, I would have been faced with finding a mast sticking out of the water where my boat should have been........
Stuart
Leith (rhymes with teeth) is the port of the City of Edinburgh in Scotland. A Leither is someone who comes from that area.
I must go down to the sea again, to the lonely sea and the sky - I left my shoes and socks there, I wonder if they're dry?
