Old 10-25-2009
dacap06 is on a distinguished road
Send a message via Yahoo to dacap06
Alcohol Tank Question
After owning the boat a year, I finally plucked up my courage today and worked on the pressurized Origo stove/oven. Turned out it wasn't bad at all - follow the directions for priming and it works like a champ. But it did require replacing the shutoff valve on the alcohol tank. The packing was shot and it leaked all the pressure out in less than a minute.
And speaking alcohol tank -- there may lie a problem. There was some old alcohol in the tank that was well and truly gross! It was a dark reddish brown, as if it had absorbed a lot of rust (presumably from the tank). I have no clue how long it had been there, but the boat was on the hard for two years before I bought it, so that alcohol sat for at least 3 years. I dumped it and put in a pint of new stuff before trying the stove. But I'm wondering now -- does all that discoloration mean the tank is rusting? Is the tank shot and should be replaced? What say the cognoscenti here?
DaCAP
T. P. Donnelly
S/V Tranquility Base
1984 Islander 30 Bahama
Pasadena, MD
Flexible holding tank installation sarafinadh Gear & Maintenance 29 10-17-2009 07:46 PM
Holding tank question c172guy Cruising & Liveaboard Forum 6 10-06-2006 11:01 AM
Below Deck Plastic Fuel Tank Grounding Question Panacea1 General Discussion (sailing related) 3 06-29-2006 07:15 PM
'68 M34 Water Tank Fill Hose Question dancrosswis Morgan 0 04-01-2006 02:07 PM
Tayana 42 Fuel Tank Question jdmrussell56 Gear & Maintenance 2 07-29-2001 07:17 AM
