10-26-2009
I don't know much about the Halon replacement agents, in the Army we still use Halon in our vehicles.
I know you said you didn't want to, but if you are considering to install a manual pull station or 2, as I plan to do when I overhaul my future boat; take into consideration the old system has a substantial concussion effect when fired off. Depending on how close you are to the units when it fires off, it could severely injure someone, including but not limited to permanent hearing loss (I have seen this personally); let alone the damage that may result to a fiberglass structure. Even with a pull station or 2, I plan to still have at least 2 hand held extinguishers readily available on board.
Now, I since I am unfamiliar with the new Halon replacement systems this all may not apply, but it is worth considering.
Take Care!
Ben
