Old 10-26-2009
daltom is on a distinguished road
Horizontal windlass challenge
Hello all. My 1992 Catalina/Morgan 45 CC has a horizontal windlass mounted below the deck inside the anchor locker. Keeps a nice clean deck, but only about 60% of the chain stays engaged in the windlass. If it gets strained, the chain slips and down goes the anchor. The second problem is that, when under load, the chain occasionally stays engaged in the windlass, creating over wrap. Has anyone found good solutions to these problems?
Thanks.
Old 10-26-2009
Bender of Nails
Deadeye is on a distinguished road
Does the rode lead into the locker through a hawse or is there a fairlead to come down from the deck ?
Sounds like you might need a straighter run onto the gypsy, assuming it's not too small for the chain of course.
That's just a guess, a pic of the deck layout might help.
"Verbosity leads to unclear inarticulate things"
~Dan Quayle
Old 10-27-2009
The anchor locker opens to provide unobstructed access to the windlass and rode. The aft roller on the bow roller provides a good fairlead to the gypsy, and the chain is the right size for the system. I have considered mounting another roller below deck, forward of the windlass to increase the contact on the gypsy. This would have to be a strong installation, of course. I also need something to disengage the chain from the gypsy. Are those normally on a gypsy, or does the chain usually separate on its own?
I'll try to get a pic up later.
Thanks
Old 10-29-2009
KeelHaulin's Avatar
STARBOARD!!
KeelHaulin will become famous soon enough KeelHaulin will become famous soon enough
There is an additional piece for some windlasses called a "chain stripper". It looks like a wedge shaped bar that goes into the groove of the gypsy and will pop the chain off of the gypsy when it contacts the stripper. On the following parts schematic for the SL 510 it's item #60
http://www.slspares.co.uk/Hyspeed%20510.pdf
Your chain should engage the windlass for at least 90 degrees for it to be able to hold the chain and keep it from slipping.
Windlass - Horizontal or Vertical? PBzeer Gear & Maintenance 8 03-03-2006 05:51 AM
Choosing and Installing an Electric Windlass Sue & Larry Gear and Maintenance Articles 0 09-06-2002 08:00 PM
The Great Windlass Debate SailNet Seamanship Articles 0 11-30-2001 07:00 PM
The Great Windlass Debate SailNet Gear and Maintenance Articles 0 11-30-2001 07:00 PM
