10-27-2009
I believe it is a double-braid as it uses the same core-to-core splice that is used for T900. The reason it uses a core-to-core splice is that the core provides the bulk of the strength of the line, and the cover is primarily for abrasion/UV protection and ease of handling.
Originally Posted by j34035
I cannot find anywhere in the description of this line, is it a double braid or parallel core? Anyfeedback or experience from current users. Looking to use as jib sheets.
DD
