Mast/deck seal - SailNet Community
Blogs
Old 10-27-2009
SVImpunity is on a distinguished road
Mast/deck seal
During some rainy weather, I noted a small amount of water running down the keel stepped mast of my Bristol. When the mast was installed shortly before I bought the boat, the installer has used a putty that remains pliable & covered the outer mast & plate with a type of tape about 4" wide & seems to be slighty elastic. I'd like to replace the tape but can't seem to find any here in the NW. Anybody have a clue as to what I should be looking for? I think the water found its way down a fine groove that is in the side of the mast & past the putty.
John Lake
Old 10-27-2009
Sabreman's Avatar
Sabreman will become famous soon enough
It's West Marine Mast Boot Tape West # 442939 ($29.99).
West Marine: Mast Boot Tape Product Display
I bought it last year and had a devil of a time getting it wrapped neatly. I ripped it off this year and installed a flexible universal collar. Great product and very neat.
Sabre 38 "Victoria"
Old 10-28-2009
Thanks for the info...since I posted I've been speaking to a rigger locally who is coming to check the rigging this week & we discussed the various ways of sealing. The mast was installed with Spar-Tite which should have prevented leaks....but there you go..you never know do you?
Old 10-28-2009
pegasus1457's Avatar
Arf!
pegasus1457 is on a distinguished road
Spar-Tite
So far as I understand, Spar-Tite is not meant to seal the mast-deck joint. It is there to position your mast correctly in the hole in the deck.
I second the opinion of the other poster re the mast tape - a waste of $$.
I am waiting for the mast to come down so I can install a boot.
Fluctuat nec mergitur
Old 10-28-2009
knothead's Avatar
There is no reason that you have to wait until the mast is removed to install a waterproof and attractive mast boot.
Have you considered using a piece of stout canvas, which can be sewn, painted and waterproofed quite easily? I'm sure any good sailmaker or canvas guy could whip one out for you in a trice.
Even if you wanted to take the easy way out there is still the option of using a Universal mast boot.
Mast Boots
I have always found these plastic boots to be much more unwieldy than fabric ones. But they do include the glue.
Ron Paul 2012
"wikijar"
Old 10-29-2009
MyBoatWorks's Avatar
Jerr - Shipwright, rigger
MyBoatWorks is on a distinguished road
Sabreman & Knothead - I've had good results with both but remember a fantasy of using licorice & chocolate last time I Jury-Rigged that leak... But that may be because the food wasn't the best on that trip.
I'm a shipwright, rigger and professional sailor, in business as My Boat Works, in Los Angeles. I also make super quality, High-Definition instructional boating movies! I'm here to give my expertise to boaters, as I was helped. It's my pleasure to help you enjoy activities I love so. Cheers! - Jerr
Old 10-29-2009
NoahsArk73 is on a distinguished road
Tape
The best tape for sealing I have found is "rescue tape" originally designed for aircraft. The first time I saw it was about 10 years ago at the Reno Air Races. The tape adheres only to itself and stretches and holds quite well: wet, uv, cold, or hot (originally designed for quick patching hoses). The stuff wears out in about 2-3 years depending on the application, but considering its universal properties, worth it. Now you can find the stuff at hardware stores different: lengths, widths, and colors for under 10 bucks, a fraction of what I spent first time at Reno. I keep it in my truck, boat, house, workshop anywhere I store duct tape.
Old 10-29-2009
CharlieCobra's Avatar
On the hard
CharlieCobra has a spectacular aura about CharlieCobra has a spectacular aura about
Oh Joy had the mast box and mast base wrapped with shrink wrap (the thick white variety) and covered with a nice canvas boot. Never leaked, even with green water washing over it.
Baggett and Sons Marine Restoration
The Landing at Colony Wharf
Bellingham, WA.
Old 10-29-2009
T37SOLARE's Avatar
Tartan 37C
T37SOLARE is on a distinguished road
Spartite eliminated 99% of the water entering the boat from the mast, now the only water from the stick is what gets blown into the sheaves & other openings in the mast, and that's minimal.
Same experience from my brothers boat, and he's pulled the mast several times and it's still dry as a bone.
Spartite website
The Spartite ring shrinks less than one thousandths of an inch and when installed properly will radically reduce or eliminate leaking at the partners.
SOLARE
T-37 #442
Old 10-29-2009
whigmaleerie is on a distinguished road
speak to your local sailmaker (im a sailmaker) it is very easy to make a collor to fit around the mast with it in place, collor can be hand stitched in place and a bit of sealant and a jubily clip around the top will sort out any leaks, no need for fancy taps etc
Shaft seal Edo Kazumichi Gear & Maintenance 9 11-23-2006 12:03 PM
Deisel Rear Main Seal pma_foyl Gear & Maintenance 1 06-22-2004 08:24 AM
Packless Shaft Seal (PSS) bkdehuff General Discussion (sailing related) 4 04-20-2004 06:41 PM
Rear Seal Replacement tm3 Gear & Maintenance 2 01-07-2004 04:30 PM
Real Seal stuffing box maintenance MarkClayton Gear & Maintenance 3 07-08-2002 06:52 AM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
