Old 10-27-2009
QuickMick's Avatar
QuickMick is on a distinguished road
remove set-in port lights
im trying to salvage port-lights from a hunter and a catalina, but dont see any external/internal screws, seems to be bedded inside the hull. any idea how to get these out? saws-all?
also the skylight kinda deals on the hunter--i removed the screws but am having trouble pulling them out of the bedding and dont want to crack them, is there some type of solvent i can use to soften them up or something?
thanks,
Quinn
How inappropriate to call this planet Earth when it is quite clearly Ocean ~ Arthur C. Clarke
Quinn McColly
Yacht Broker
Old 10-27-2009
If they are the newer Catalina/Hunters with the glued-in portlights I'm not sure you can really get them out in one piece unless the adhesive has already failed. I believe there are some solvents you could try, but would worry about the solvent attacking the lens of the port too....
As far as the hatch goes you may be able to cut the caulking with a fine wire like a guitar or piano string. Use a couple of pieces of dowling as handles.
1984 Fast/Nicholson 345
crazed port lights PerryD19 Gear & Maintenance 3 04-26-2004 03:53 PM
Light Lists, Lighthouses, and Visible Ranges Jim Sexton Seamanship Articles 0 06-19-2003 08:00 PM
Light Lists, Lighthouses, and Visible Ranges Jim Sexton Her Sailnet Articles 0 06-19-2003 08:00 PM
Set and Drift Made Simple Jim Sexton Seamanship Articles 0 04-19-2000 08:00 PM
Advanced GPS Interfacing Jim Sexton Gear and Maintenance Articles 0 10-07-1999 08:00 PM
