Adding tangs for running back stays - SailNet Community
post #1 of 6 Old 10-28-2009 Thread Starter
Tundra Down
downeast450's Avatar
If I need to add tangs for running back stays how do I get a compression tube into the mast?
George
downeast450 is offline
post #2 of 6 Old 10-28-2009
If you are using a 3/8" bolt, you would drill a 1/2" hole through the mast. Then make your 1/2" OD - /3/8" ID tube long enough to fit flush on each side of the mast. You just insert it with the bolt from either side.
knothead is offline
post #3 of 6 Old 10-28-2009 Thread Starter
Tundra Down
Thanks, I realized that about 10 minutes after the post. Too much going on here. Time to go for a sail.
George
post #4 of 6 Old 10-28-2009 Thread Starter
Tundra Down
Should I use a SS tube or an aluminum one?
post #5 of 6 Old 10-28-2009
I would recommend an aluminum compression tube. Also that you completely and generously coat the stainless bolt with Lanacote or equivalent.
knothead is offline
post #6 of 6 Old 10-29-2009 Thread Starter
Tundra Down
Thanks again.
George
St. Maartin, St. Barts & Anguilla bbayer4230 Chartering 2 04-23-2006 06:04 PM
The Beauty of Turning Back Kevin Jeffrey Cruising Articles 0 11-13-2000 07:00 PM
